Results 1 to 9 of 9
    Oct 2016
    Default Chevrolet Lacetti DPF and EGR off
    would someone please make a DPF and EGR off on the below file.
    Please manual solution if possibble
    Regards
    UNI
    May 2016
    your file off
    dont forget thanks and report that all is ok
  3. The Following User Says Thank You to tricore3 For This Useful Post:
    Unichip77 (27th April, 2017)
    Oct 2016
    The software is in the car but the mechanic delaying remove the the filter body.
    Will repoert when done.
    Oct 2016
  6. #5
    Jan 2016
    Quote Originally Posted by tricore3 View Post
    your file off
    any chance to ge a password please?
  7. #6
    Autotecno2006's Avatar
    Aug 2009
    Why Do You Want Pass for This File ?
    Post your Own File and its will be done for you :
    Regards P
  8. #7
    Jan 2016
    Quote Originally Posted by Autotecno2006 View Post
    Regards P
    any help will be appreciated
  9. #8
    Aug 2009
    Here You Go , Report Ok
    If I Have helped you then Hit The Buttons Ok (Thanks & REP )
    Regards P
  10. The Following User Says Thank You to Autotecno2006 For This Useful Post:
    lobsterosxxx (28th June, 2017)
  11. #9
    Jan 2016
    Regards P
    Thanks a lot. Do I need to disconnect pressure sensor or EGT sensor?
