Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    Dec 2016
    Poland
    Default SAAB 9-3 add firginised key failed
    Hi All.
    If someone can help and explain what is wrong.
    Car is Saab 9-3 2008
    I would like to reuse key from different car.
    So buy new PCF7946 and soldered it - seller say that it is already preceded to SAAB.
    But when adding it via Tech2 if failed, Tech2 says that this is "NEW (never added).
    So I managed to obtain zed-bull mini clone. Can read all pages on Hitag2 tab on EFfi, but hardware and software says that transponder is locked.
    So buy, new PCF7946 (clean one), zeb-bull mini also says that this is locked, I've try to precode it via zed-bull, but also locked. After precoding only remote pages has changed. Still can not add it via Tech2.
    Appreciate all suggestions.
    Maciek
    PS. could some moderator correct the topic? I've made mistaken...
    Dec 2016
    Poland
    I can add that 1 per 20 times when read the chip it show as: "mode: cipher + manchester"
    So what is wrong? All chips bad, or a bad tool?
    Jun 2010
    In a van down by the river
    Please show picture of the Hitag2 data. I have correct config here and I will compare.
    Show all 12 pages, not 8.
  4. The Following User Says Thank You to indienick For This Useful Post:
    szengen (26th April, 2017)
    Dec 2016
    Poland
    Quote Originally Posted by indienick View Post
    Please take a look on this one. What is wrong?
  6. #5
    Dec 2016
    Poland
    Please, can anyone help?
    I can only add that after failed add of virgin key, page 3(TMCF) has changed (first part from 06 to 0E) and remote is not active.
    I can change it back then, but still no luck.
    Screenshot from another key. But both looks the same, I've did a test on both.
  7. #6
    metalik's Avatar
    Mar 2012
    Hello, you have one working key for this car?
  8. #7
    Dec 2016
    Poland
    Quote Originally Posted by metalik View Post
    I've check it on both scenarios.
    1. when adding to 1 working key
    2. when adding to virgin CIM.
  9. #8
    Bllinda's Avatar
    May 2010
    Baltic
    Quote Originally Posted by maciekni View Post
    All this is verified
    You waste your time ....
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  10. #9
    Dec 2016
    Poland
    Quote Originally Posted by Bllinda View Post
    Thanks, but do not fully understand what you mean.
    So, whats then?
  11. #10
    Bllinda's Avatar
    May 2010
    Baltic
    And the key to running a car ....
    today
  12. #11
    Dec 2016
    Poland
    You want to post it here?
  13. #12
    Bllinda's Avatar
    May 2010
    Baltic
    I'm thinking here DK already written
    today
  14. #13
    Dec 2016
    Poland
    Dear Bllinda, thank you for commitment.
    Maybe I'm a bit blind but can not find the answer.
    Can I ask to answer few question.
    Is this precoding i've provided correct?
    If it is wrong, where I can find correct one?
    If this precoging is correct, then what is wrong? Key, transponder, car or Tech2?
    Many thanks for replay.
  15. #14
    Bllinda's Avatar
    May 2010
    Baltic
    I also have to work and have no time to be here DK
    Refused to help.
    that you might go deeper than do find yourself DK
    today
  16. #15
    P&D's Avatar
    May 2010
    Why do you put useless answers to questions.........asked ?
