Results 1 to 3 of 3
    Top Poster + Wodzu's Avatar
    Apr 2013
    Default Ford Focus mk2 1.8 tdci kkda sid202 wiring diagram
    I need wiring diagram for ford focus mk2 1.8 TDCI KKDA. I don't have communication with ECU (SID202). I need to check power supply and CAN wires.
    Best Regards
    I have no communication with Ecu, I have to check the power and CAN wiresI have no communication with Ecu, I have to check the power and CAN wiresI have no communication with Ecu, I have to check the power and CAN wires
    If I was helpful, do not forget to click thanks
    after ignition: 3C3
    after relay ecu:1K2 1K3 1J3
    masa:2K2 1H4 1J4 3H4 3G4 1K4
    can L:3A3
    can H:3A4
  3. The Following User Says Thank You to radoslawwiklik For This Useful Post:
    Wodzu (27th April, 2017)
    Apr 2013
    Thanks, problem solved. There was no power on 2G4 from battery.
  5. The Following User Says Thank You to Wodzu For This Useful Post:
    ervinhodo (5th January, 2024)
