Results 1 to 2 of 2
    Jul 2009
    GODS COUNTRY
    Default Replace 'dark' channels with IPTV ones
    Is it possible to delete the dark none working channels and replace them with working IPTV from my subscription ones and stop the none working ones from coming back each time my bouquets update?
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    I take it you're talking about ABM? You can replace the non working channels with IPTV channels but when you rescan the bouquet will be replaced and the upto new bouquet will be produced, whether you can add the IPTV channels to the custom 'sd_sat_282_sky_uk_CustomLCN.xml' or 'sat_282_sky_uk_CustomMix.xml' and it will keep the channels is something I haven't tried it, it might work it might not but it could be worth a try, both these files are located at /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoBouquetsMaker/custom . Some instructions on how to modify the files are in the thread download here;
    http://www.digital-kaos.co.uk/forums...=1#post2748528
