Fiat stilo IAW 5nf pin
Results 1 to 10 of 10
    Apr 2016
    Default Fiat stilo IAW 5nf pin
    Hello guys, it's possible to extract pin from 95160 dump from IAW 5NFT9?
    Thankss
    IAWNFT9_ST95160_ori.rar
    i_shot_the_sheriff's Avatar
    Nov 2008
    Pin 64163 mate
    Locksmith Hungary's Avatar
    Aug 2015
    Hungary, Pápa
    "ß$¤ßłpúőpúßßłŁ$ßßłjáßßłßł$×÷łŁł¤ß=
    yellowstilo's Avatar
    PIN is 66155......
  5. The Following User Says Thank You to yellowstilo For This Useful Post:
    Locksmith Hungary (28th April, 2017)
    Aug 2015
    Hungary, Pápa
  7. The Following User Says Thank You to Locksmith Hungary For This Useful Post:
    yellowstilo (29th April, 2017)
  8. #6
    Apr 2016
    FVDI tells me the same pin, but not tested yet...
  9. #7
    did you notice there is a "thanks" button on the left ? using it will be good for being helped in the future....
  10. #8
    stalonerambo
    Guest
    Question
    Quote Originally Posted by Tubarrete View Post
    Thankss
    HI FRIEND, HOW DID YOU READ THIS ECU,, WAS ONBOARD OR OFFBOARD,
    WAS BY UPA//
    CAN YOU SHARE CONNECTIONS TO READ IT ONBOARD,, OR SHOULD I make a hole AND READ BY CLIPS ONBOARD//
  11. #9
    stalonerambo
    Guest
    HI FRIEND, CAN YOU SHARE HOW DID YOU READ IT,, WAS BY UPA, ONBOARD OR OF BOARD, IF WAS ON BOARD, CAN YOU SHARE CONECTIONS OR HOW DID YOU DRILL THE ECU TO GET ACESS TO ST95C160
  12. #10
    doctore's Avatar
    Nov 2015
    Colorado Denver
    You can duet with fvdi read write and virgin this ecu via obd tested
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  13. The Following 2 Users Say Thank You to doctore For This Useful Post:
    billarisa (1st May, 2017)
