What is the ECU and immo model?
Sent from my SAMSUNG-SM-N910A using Tapatalk
ECU HITAHI 33920-77EA0
Immo Mitsubishi 33970-70E01
Hello my friend
Write back this synchro ecu file and try to start the car
The machine started all thanks
Do you think these synchro files will work for my ECU and Immo ?
Friend read your eeproms x24c01 of immo box and Jm86 or 93c56 of ecu then post here, i will help you.
please help me
same problem whit suzuki vitara 2.0 16v
ecu hitachi 33920-78EN
immo box mitsubishi 33970-70E20
I tried immo off with immodec car started 1 timeI trie
d imthanks...mo off with immodec car started 1 tim
evitara.rar
I used the dumps KEY4MAN posted and programmed the key by OBD. the car starts 3 times, then the Check ligth blinks again
I even tried programming the key by dump with Tango but the car doesn?t start
I have the original dumps, but it seems the original JM86 (93c56) Eeprom was damaged, because the dump reading doesn?t have logic or is completely different to other Vitara dumps, then I wrote the dump in a new 93c56 Eeprom
These are the original dumps
GVitara2000.rar
Please help me solve this problem, thanks in advance
i swapped oki eeprom whit st 93c46wp
how to write write protection in this file ????
For immo off i haven't any idea, from post #1 load the good file x24c01 to your eeprom then post your reading here.
Something really strange happen, I used the dumps KEY4MAN posted and programmed the key by OBD. the car starts 3 times, then the Check ligth blinks again
The strange part is that I turn the key to the ON position, turn OFF, turn ON again for 16 seconds, then the car starts again.
I have to do the 16 seconds process everytime I want to start the car
Please let me know if somebody had a similar problem
soved whit julie emulator by carlabimmo
Thanks !!!
Yhoni (14th January, 2021)
