Results 1 to 1 of 1
    Jan 2016
    Default Volvo s80 T6 ME7 0261204559 359462
    Hello. we have little project going on with a Volvo s08 T6. We converted it to single turbo and larger 1000cc injectors. Also added a 4bar map. The car worked great except when you took your foot off the accelerator it would go into limp mode. We had a friend of a friend do some changes to the map to work with the 1000cc injectors and larger turbo. now the car runs a little rough and AFR is 17-18 on idle (goes over scale with throttle) do you guys mind taking a look at the changes he made and perhaps fine tune it a little if possible. will post ori + mod file
    Running 1000cc@3bar injectors
    Garret GT3582 turbo
    Also if possible to do a rear lambda delete since those are not connected atm
