Results 1 to 8 of 8
    Aug 2009
    4
    Downloads
    30
    Uploads
    Default Help With Old Favourite DBOX2
    Came across my old Nokia DBox2 I stopped using after N3, and moved to Sat with VuDuo, but found him in the loft and been having a little search and messabout, I knew cs existed but thought the Dbox2 was too old,
    so after a little help where to begin , it has Commando 12.1.1 , it has MgCamd , but obviously doing a scan found nothing , its seems I need to update my cables.xml file and place it in Var/etc
    do I need mg_cfg in Var/Keys along with newcamd.list
    Thanks for he Help in advance
    sorry about the low post counts guys,
    regards
    Newbie scout100's Avatar
    Mar 2009
    Ireland
    Downloads
    75
    Uploads
    Yes, mg_cfg in Var/Keys along with newcamd.list
    Aug 2009
    4
    Downloads
    30
    Uploads
    cheers, think I found a cables.xml and put MgCamd 1.35 in the Emu folder but it still showing 1.22 when I restart , I have ftp the mg_cfg and newcamd.list in var/keys,
    anything else I need to update
    plasterer's Avatar
    Jun 2008
    Mersyside
    129
    Downloads
    92
    Uploads
    Need a new scan .config as vm changed scan settings
    Also can attributes need to be 755
    Hope this helps ......................Paul
    PAUL
  5. The Following User Says Thank You to plasterer For This Useful Post:
    gdf (2nd May, 2017)
  6. #5
    Aug 2009
    4
    Downloads
    30
    Uploads
    cant get this to scan any Fta or nothing, must have some file wrong somewhere,
    placed cables.xml and scan.conf in correct folder ( with CableUK as the Provider- se tin both files , set my Location manually for Liverpool 40965,571000,69520) Fast San , and nothing , when I do a brutescan if finds the old 306 transponders 45 channels but channels Like ITV1 HD which of course wong clear,
    changed to QAM/256 from 64 changing 3 to 5
    what else can I try??
  7. #6
    plasterer's Avatar
    Jun 2008
    Mersyside
    129
    Downloads
    92
    Uploads
    Try thay one mate , not sure how long ive had it
    PAUL
  8. The Following User Says Thank You to plasterer For This Useful Post:
    gdf (4th May, 2017)
  9. #7
    Aug 2009
    4
    Downloads
    30
    Uploads
    cheers scanned and found some channels but BBC 1 will not clear,so must have something incorrect , I am missing anything else , apparently Freq had changed to 595000
  10. #8
    DK Veteran chris31560's Avatar
    Feb 2010
    wigan
    92
    Downloads
    70
    Uploads
    qam256
    6.952
    that should pick up channel's.............c
    A LITTLE THANX GOES A LONG WAY
