Post here file with crash and we will look at this ...
hi, i have ford c-max 2007 after crash, i was change airbag and belt tensioner, airbag module may be clear from crashdata, now i delete all dtc from airbag module, and coding without front sensor of crash and without belt safety sensor... but on dashboard light belt and airbag error, also have errors in airbag module b1342, b1871, but in car not present passager airbag deactivate module from stock..... i think may be airbag module was bad clear from crashdata ? or not ? help please, THANKS
p.s. on screeshot only 1v on module battery, it's dont matter, but after charge 1.3v but error don't clear
belt safety sensor
Best regards.
Dragon
Romaus (17th May, 2017)
I need all details 4M5T-??????-?? or photo sticker ...
Best regards.
Dragon
this is photo sticker
Your cleared file.
Best regards.
Dragon
Romaus (18th May, 2017)
so i was write your dump install module in car, and also car show b1342 b1871 b2855 b1884.... all this errors was before write new dump..... i desolder eeprom again and read - and in receive again old file like i upload to this topic.... what can do with it ?..... may be can write file without front sensor of crash and without passager airbag deactivate module.....
p.s. i think this dump not from this car((( first time not i clear dump and i don't know what they do
hello mate try this clear file. should ok
clear dtc using diagnosis scanner
pass pm
your file identical file which upload dragon100 .... i was try this file and write about errors
now i try other file from airbag module with the same number - change VIN.... and write.... now only 1 error: B2477 configuration error.... i reconfig module to my settings but error don't delete.... show B2477.... what can do with it ??? thanks
Then your original file is bad read or corrupt, U need use other file and IDS coding, configuration ...
Best regards.
Dragon
