Results 1 to 11 of 11
    Apr 2012
    minsk
    Default FORD C-MAX 2007 airbag module
    hi, i have ford c-max 2007 after crash, i was change airbag and belt tensioner, airbag module may be clear from crashdata, now i delete all dtc from airbag module, and coding without front sensor of crash and without belt safety sensor... but on dashboard light belt and airbag error, also have errors in airbag module b1342, b1871, but in car not present passager airbag deactivate module from stock..... i think may be airbag module was bad clear from crashdata ? or not ? help please, THANKS
    p.s. on screeshot only 1v on module battery, it's dont matter, but after charge 1.3v but error don't clear
    belt safety sensor
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Post here file with crash and we will look at this ...
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
  3. The Following User Says Thank You to dragon100 For This Useful Post:
    Romaus (17th May, 2017)
    Apr 2012
    minsk
    Quote Originally Posted by dragon100 View Post
    hi, i read 95080 with x-prog-m, can you look?
    dragon100's Avatar
    Jan 2012
    I need all details 4M5T-??????-?? or photo sticker ...
    Best regards.
    Dragon
  6. The Following User Says Thank You to dragon100 For This Useful Post:
  7. #5
    Apr 2012
    minsk
    this is photo sticker
  8. #6
    dragon100's Avatar
    Jan 2012
    Your cleared file.
    Best regards.
    Dragon
  9. The Following User Says Thank You to dragon100 For This Useful Post:
    Romaus (18th May, 2017)
  10. #7
    Apr 2012
    minsk
    Your cleared file.
    so i was write your dump install module in car, and also car show b1342 b1871 b2855 b1884.... all this errors was before write new dump..... i desolder eeprom again and read - and in receive again old file like i upload to this topic.... what can do with it ?..... may be can write file without front sensor of crash and without passager airbag deactivate module.....
    p.s.
    i think this dump not from this car((( first time not i clear dump and i don't know what they do
  11. #8
    Brayn's Avatar
    Oct 2015
    Colombo
    hello mate try this clear file. should ok
    clear dtc using diagnosis scanner
    pass pm
  12. The Following User Says Thank You to Brayn For This Useful Post:
  13. #9
    Apr 2012
    minsk
    Quote Originally Posted by Brayn View Post
    pass pm
    your file identical file which upload dragon100 .... i was try this file and write about errors
    now i try other file from airbag module with the same number - change VIN.... and write.... now only 1 error: B2477 configuration error.... i reconfig module to my settings but error don't delete.... show B2477.... what can do with it ??? thanks
  14. #10
    dragon100's Avatar
    Jan 2012
    Then your original file is bad read or corrupt, U need use other file and IDS coding, configuration ...
    Best regards.
    Dragon
  15. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    Brayn (18th May, 2017), Romaus (18th May, 2017)
  16. #11
    Apr 2012
    minsk
    problem was solved... i config module(by ELMConfig) on other dump with my VIN and set front crash sensors fitted and second upfront sensor fitted
    Thanks to all
  17. The Following 2 Users Say Thank You to Romaus For This Useful Post:
    Brayn (18th May, 2017), dragon100 (18th May, 2017)
