HELP , FIAT PUNTO 93LC66, THE DUMP CAN BE FIXED?:?
Results 1 to 7 of 7
    stalonerambo
    Guest
    Question HELP , FIAT PUNTO 93LC66, THE DUMP CAN BE FIXED?:?
    HI FRIENDS, NEED HELP, A GOT A CALL FROM A CLIENT TO SEE, A FIAT PUNTO KEY, HE TOLD ME, CAR STOPPED 4 DAYS AGO, AND DIED,
    FIRST LOCKSMITH WENT THERE, AND TRIED TO recode the key, no worked,
    second locksmith took the bsi,and ecu, dismatle and said, ecu was good,but no solution,
    today i went there, took the bsi, tried to read the dump, and i got it, the original dump is corrupted,, is it possible to fix this dump
    and the ecu is iaw 5nf t6 + bory computer 93lc66,small motherboard, what can i do here, is it possible to do imo off, on this model?
    or make reset bory computer and ecu,,
    armpower's Avatar
    Jun 2009
    Italy
    Hallo
    Eprom is corrupted.The only solution is to load a dump from a working body computer, make new keys.Virginize 5NF connect all and resolve your problem.
    I have a couple of dump here so, send me body computer number so i can take a look and send you something.
    Cheers
  3. The Following User Says Thank You to armpower For This Useful Post:
    stalonerambo
    Guest
    Quote Originally Posted by armpower View Post
    Hallo
    Cheers
    THANKS FRIEND,, HERE ARE THE NUMBERS FROM BSI AND ECU 5NF,,
    armpower's Avatar
    Jun 2009
    Italy
    I can't see anything.Repost.
    Punto 188 ?
    stalonerambo
    Guest
    ecu iaw 5nf .t6 c146
    iaw 5nf.t6/hw105/26b2-k40
    bsi delphi
    46812230
    c150-12volts
    type:bc-1
    e13
    variant:base
    type f
    stalonerambo
    Guest
    bsi delphi
    46812230
    c150-12volts
    type:bc-1
    e13
    variant:base
    type f
    cant upload the pictures, is to large, but if you pm me your email i can send to you the pictures l and you can see,,
    armpower's Avatar
    Jun 2009
    Italy
    Hallo
    I don't have the same part number.
    The only difference must be in the hardware of Body.Es:Remote RF, Fog Lights ,A/C.
    But the eprom content is the same.
    Make keys with dump, virginize 5AF and write this dump in the body.
    Punto188 body 46774360 Pin 57557 93c66 16.zip
    Hope this help
