your file off
pass pm
just dont forget to press thanks
your file off
pass pm
If I helped, please, use magic buttons reputation+thanks
granaino5000 (22nd July, 2020), haitam2017 (24th December, 2017)
tel me if works or not
work 100 % i have good solution
can u send me pass please
i have a solution for sid801a but not for sid801
post your dump
Zine DDine, can you send me the file off for this dump!? Really thanks! I will press thanks and all you want.
Working with : Bosch FLA Dyno , KTS 650, WINOLS , CMD Master, Byteshooter Master, SPI, Powergate,CADOPRO, selfmade tools
Try this and post results . Pass is in your pm .
regards
hui zine ddine , what is the pass please ?
For an IMMO OFF of a SID 801, is it enough to program the EEPROM 93C56, or is it also necessary to program the FLASH 29F400?
only eprom, 16bits playback.
Small circumstances produce great events : 02.47-tranquillité:
Pour une IMMO OFF d'un SID 801, suffit-il de programmer l'EEPROM 93C56 ou faut-il également programmer le FLASH 29F400?
Hi mate,
I´m looking for the tested immo off for 5WS40023F-T?
Thanks in advance
rokibar (5th March, 2019)
alclot (4th March, 2019), granaino5000 (22nd July, 2020)
