Results 16 to 30 of 38
  1. #16
    Mar 2018
    Really in need key for 7.6.2.240 pc id F26F288A .
    Many thanks.
  2. #17
    Oct 2015
    Quote Originally Posted by skankybiker View Post
    Many thanks.
    try
    Basic :0001BB1260468FD5CR
    Lite :001D061DDF783785FA
    Pro :002B3EC9AEF0AF35FA
    RSGR :0035FB357576EA15CR
    Industrial/power :004AD71D75864C05CR
    ODB-RSGR :0058A8DD49FB4355CR
    ODB :006483FC73F22B15CR
    RSGR+ :007FD6AC06C9EA75CR
    Pro+ :00888253C8C88CF5CR
    ECM Pass :WSS111FC720B8925CR
    OEM,ECM Pass :ZSS73BE37D974025CR
    Fieet Calibr :FSSE7FFA10C4ABD5CR
    Dot forget to press "Thanks" &"Rep"
  3. #18
    Sep 2008
    Basingstoke UK
    Help ! Im just wondering if I've done something wrong here as my codes on Insite have expired. I realise that the date on laptop has to be regressed back to be able to do recals. But I've just read something about a date unlock code, what is this, do I need this to stop Insite expiring ?
    Im assuming I need new codes anyway, PC id is B2998981 vers' 7.6.2
    You have to excuse me, im a bit of a novice when it comes to unlock codes for Cummins Insite. Last time it was done for me !
    Thanks in advance.
  4. #19
    Oct 2015
    Quote Originally Posted by Kniloc View Post
    Thanks in advance.
    Basic :00099EE7691498A5EF
    Lite :0011340266E1FDA5EF
    Pro :002E3B380B3D7CC5EF
    RSGR :0038F9800604E345EF
    Industrial/power :00421D17EC068655EF
    ODB-RSGR :005CA68ADE159995EF
    ODB :0061BFB7FDE12385EF
    RSGR+ :007F3C03C5318EF5EF
    Pro+ :008FF66F32577B65EF
    ECM Pass :WSS782F85DC271B5EF
    OEM,ECM Pass :ZSS9E89B72BFF065EF
    Fieet Calibr :FSS08812BC653F55EF
  5. The Following User Says Thank You to shadowcar For This Useful Post:
    Kniloc (18th March, 2018)
  6. #20
    Sep 2008
    Basingstoke UK
    I just knew this was going to go bad for me ! Ok, so I've set the date to 1st Jan 2014, I assume this is correct ? I've then reinstalled insite 7.6.0 updated it to 7.6.2 Ive entered the first code, thanks to shadowcar, and all seemed good. It then asked if I wanted to enter functionality codes, I assume these to be the lite, pro, codes etc. After entering the lite code its popped up and said that Insite has detected an invalid PC date and has been locked into read only mode and is asking to verify the pc date and time. I can press ok to enter a code or cancel to take me into read only mode. on entering a code it told me that the code was invalid.
    I am also now getting a verification code coming up, 404A6-1AD9D as well as the pcid of B2998981
    Any suggestions of what I should do would be much appreciated. (I know what I want to do with it at the moment !)
    Edit - Ive now just found that the verification code has changed, it is now 3444A-0B1A3 ( i guess i have to leave this running now until I get a code), Sorry another question, do I have to enter all the above codes ?
  7. #21
    Oct 2018
    Hi all, I am in need of all the Activation Key for Cummins Insite 7.6.0.272 PC ID FCDC4361 any help would be greatly appreciated!
  8. #22
    Dec 2018
    Hi Im in need of a key for insite 7.6.2 any help would be great
    pc id 9DC20D9 Thankyou.
  9. #23
    Aug 2016
    Oklahoma
    Default kniloc
    This may help you. Merry Christmas!
    Please hit the "Thanks" and "Rep" Button if I helped you. Thank you.
  10. #24
    Aug 2016
    Oklahoma
    Quote Originally Posted by crusher99 View Post
    Unlimited
    Basic 000-E34-CC3-FFA-741-000
    Lite 001-F13-332-DA9-2DD-000
    Pro 002-02D-A06-20C-829-000
    RSGR (Road Speed Governor Restricted) 003-91F-B49-50C-DCB-000
    Industrial / Power Generation Applications 004-4AA-29D-63E-2B8-000
    OBD-RSGR 005-3E6-76B-3D9-188-000
    OBD 006-512-BDA-F2F-11B-000
    RSGR Plus 007-0DD-94E-AC0-9AB-000
    Pro Plus 008-909-A4B-3C5-4C0-000
    Usage counts : 100
    Fleet Calibration Counts FSS-D09-107-F68-FD8-5ML
    OEM, ECM Password Removal ZSS-A4D-1F7-656-151-5ML
    ECM Password Removal WSS-93B-B80-F44-810-5ML
  11. #25
    Aug 2016
    Oklahoma
    Quote Originally Posted by timbir62 View Post
    Your PCID must be 8 characters.
  12. #26
    Jan 2019
    G'day is there anybody that can help me out . I need the password to unlock insite pro 7.6
    Pc I d 0271FF5E
  13. #27
    Jan 2019
    Sorry it's insite pro 7.6.2.240 sp5
  14. #28
    Jan 2019
    I'm looking for Insite v 7.6 to download. Can anybody provide me with the file?
  15. #29
    Jul 2016
    Need date unlock code for 7.6.0.272
    Pcid: 7FBEDB08
    Another(Security)code(?): 243C9-D8C57
    Thanks!
  16. #30
    Apr 2019
    INSITE key for 7.6 Full please
    ID 30125141
