Results 1 to 5 of 5
    xant14's Avatar
    Mental Mowbray
    Default Redundant router
    I have a Buffalo AirStation WHR-HP-G54 Wireless DSL Router/Access Point with 4 port switch - High Power
    https://www.amazon.co.uk/Buffalo-Air.../dp/B000BQ5ORM
    I used to have it attached to my Virgin cable modem. Now with a new modem/router.
    Can this be used elsewhere in the house inputted with a ethernet cable from new modem to make a 4 port thingy?
    And will the aerial boost wi-fi signals?
    Or should I FIITC.
    Rob
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Yes it can be used elsewhere. Just setup as a ap (access point)
    If you want 'seemless roaming' have ssid and all security matching main networks.
    Personally I have 3 routers acting as access points in various locations and different radios. Works well instead of repeaters
  3. The Following User Says Thank You to cunny For This Useful Post:
    xant14 (4th May, 2017)
    xant14's Avatar
    Mental Mowbray
    Quote Originally Posted by cunny View Post
    Cheers Cunny. Don't know half of what you said, but inspired me to have a go.
    All the best bud.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Forgot to mention that have main router handle all dhcp requests and turn off in second router otherwise you could end up with ip conflicts
  6. The Following User Says Thank You to cunny For This Useful Post:
    xant14 (9th May, 2017)
    And add sequential IP's to secondary router such as 192.168.1.2, 192.168.1.3 (192.168.1.1. is probably your main router).....adjust pool range in DHCP of main router outside these adresses e.g.:192.168.1.100-.192.168.1.240.
  8. The Following User Says Thank You to Inovator For This Useful Post:
    cunny (9th May, 2017)
