Votre d?charge claire
ryn079 (6th May, 2017)
Will check and get back,thanks again.
Can someone give me a good dump as ECU is not being recognised by scanner?
In case my help has been useful do not forget the magic buttons. ( Thanks and * Reputation ) !!!.
ATTENTION!!!
Attempting to clean files is only to help members. By using these files, you agree to assume the consequences and are aware that all liability for any damages is entirely yours.
Thank you!
megabits.
ryn079 (16th June, 2017)
Will check and get back after test.
Haven't tested this yet but it is the same dump as generated by the airbag service tool program. Can someone please confirm if it is good or not?
hi guys,
i installed the airbag ecu but one of the errors says that the ecu does not match car, could it be i uploaded a dump from another car with same ecu as i tried a million dumps? also, what resistance should i use to test the seat airbags, and to which wires should i connect as the polo from 2013 has a 3 wire plug, one brown and the other 2 i forgot the colour. will the "ecu not matching car" error put the airbag light on?
Resistor 2,2ohm or 3,3ohm , join to 2 wires (which colours in ?) ???
Best regards.
Dragon
ryn079 (23rd June, 2017)
