Results 16 to 30 of 32
  1. #16
    ssmax's Avatar
    Aug 2016
    now we have a winner, AT 25128B from ATMEL...
    Attach dump, please it is possible a tested solution, i feedback
    I appreciate when you give me "Thanks and Reputation"
  2. #17
    slick_dick's Avatar
    Essex
    part number please just to confirm i see if i have tested solution
  3. The Following User Says Thank You to slick_dick For This Useful Post:
    ssmax (2nd December, 2017)
  4. #18
    slick_dick's Avatar
    Essex
    VOLVO XC60 2014 P31406637 0285012268 << i have a tested solution for this
  5. The Following User Says Thank You to slick_dick For This Useful Post:
  6. #19
    ssmax's Avatar
    Aug 2016
    Yes, it is, same as mine
  7. #20
    slick_dick's Avatar
    Essex
    here you go, manual cleared from a tested solution
    all the best
    regards
    slick_dick
  8. The Following User Says Thank You to slick_dick For This Useful Post:
  9. #21
    ssmax's Avatar
    Aug 2016
    thanks friend, i will wirte now
  10. #22
    mapino's Avatar
    Netherlands
    Hi all
    i have here a Volvo XC60 2015 with P31406637 Partnumber 0 285 012 268
    and want to clear the crash in this module can you help me with this one
    From the netherlands
  11. #23
    slick_dick's Avatar
    Essex
    your file cleared
    join date 2009 .. time you started helping out a bit more mate
    pass in pm
    good luck
    slick
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
  12. The Following User Says Thank You to slick_dick For This Useful Post:
    mapino (21st October, 2018)
  13. #24
    mapino's Avatar
    Netherlands
    Thanks Slick for your efford
    i tested the file in the XC60 airbag module but it did not clear
    what i noticed is that after words when i Read the file back it changed again
    see attachment i also took a snap of the fault codes
  14. #25
    slick_dick's Avatar
    Essex
    i noticed the same with ypour original read!!
    your original crash file looked wrong to begin with
    my attempt at clearing the above was trying to repair the data and remove crash
  15. #26
    mapino's Avatar
    Netherlands
    thanks for that
    do you still have the file that you loaded in to your XC60 mabe i can load that and see what happeands
    what can i do further
  16. #27
    slick_dick's Avatar
    Essex
    can you post diagnostics codes and fault description??
    did you remove eeprom from board before reading??
  17. #28
    mapino's Avatar
    Netherlands
    did you remove eeprom from board before reading?? = Yes But the previous owner let sombody that i do not know work on the module
    Thanks again
  18. #29
    slick_dick's Avatar
    Essex
    try this
    Also be aware there is another variant in V60 that is same as XC60
    good luck
    slick
  19. #30
    mapino's Avatar
    Netherlands
    Slick
    thanks for helping but it did not help i am stuck now
