ssmax (2nd December, 2017)
Joblack (6th November, 2017), kierownikszatni (6th May, 2017), ssmax (2nd December, 2017)
Unable to clear faults? Any strange faults?
Sent from my Nexus 5X using Tapatalk
@marciomodulos Yours dump works fine. Thanks
@pagautas No, dump works like a charm. Why are You asking?
marciomodulos (6th May, 2017), ssmax (2nd December, 2017)
Hello friends i need he same solution, please could you send me pass pm
I appreciate when you give me "Thanks and Reputation"
post your file friend
frind i cant find 95128 mem, could you help me please
Its under the big arse white fuse .. the one infront of you
or see this
https://www.cardumps.com/unit/show/v...bag/file/33195
regards
thanks see now, not fuse, are capacitors...
ok just notcied too
on this toyota aygo unit
loooooong arse capacitor
i read like 95128 and have only "00" its possible that memory are bad? i solder in adaptor, so no bad contact is possible
clean the eeprom with iso then resolder to device and read again
Not friend, only "00" i note that its not an ST memory, only saids H128, so i will read with another maker
