Results 1 to 15 of 15
    Top Poster Silver740's Avatar
    Nov 2008
    Estonia
    Default Daewoo Lanos 2003 1.5 Delphi-Delco 09388019 DLBY immo off?
    Hi to all,
    How bypass immo in ecu Delphi-Delco 09388019 DLBY, serv. no. 12201599.
    Immo box IM710, DWMC: 96279331
    Only emulator?
    Thanks,
    belgrade,serbia
    is that hybrid?if its hybrid you can do immo off ,but is very hard to unsolder eprom
  3. The Following User Says Thank You to vladanr For This Useful Post:
    Silver740 (6th May, 2017)
    Nov 2008
    Estonia
    thanks, yes hybrid. i can read 95020 on the board, but cant write file back. xprog says buffer error.
    belgrade,serbia
    we are unsolder eprom and program it on desk ,
  6. The Following User Says Thank You to vladanr For This Useful Post:
    Silver740 (8th May, 2017)
    Nov 2008
    Estonia
    Thanks, thats correct. must desolder.
  8. #6
    Apr 2017
    how do you remove the eprom from ecu
  9. #7
    gkogkolos's Avatar
    Oct 2015
    Athens, Greece
    Default IMMO OFF
    Bro,
    If you are sure you read it, try to cut 95020 eprom pin number 8 and try to start your engine !!
    If this doesnt work, then use my file and your car will start for sure.
    Post result here bro !
    Press Reputation +1 = Password in PM
    regards
  10. The Following 5 Users Say Thank You to gkogkolos For This Useful Post:
    durdur (5th September, 2018), guuciek (5th July, 2017), MARIKO (24th November, 2017), publiperro (16th March, 2022), zeljko84 (11th January, 2018)
  11. #8
    Apr 2017
    8 pin is vcc without it the ecu wont work at all
    i have tacuma with the same eprom and ecu, have a programmer but i cant desolger it from its fuc..ng ceramics to read write
  12. #9
    gkogkolos's Avatar
    Oct 2015
    Athens, Greece
    Its very very hard to desolder the eprom from this ecu, I had took hours one day to clean - desolder it
    When you fix it, keep us informed with the way you did it
    regards
  13. #10
    Nov 2008
    Estonia
    i was cut legs, then desolder back. And works. And unplug immobox.
  14. #11
    Apr 2017
    desolgered it with the rework station
    it should be heated
  15. #12
    FRANCE
    Hi Gkogkolos,
    I've a probleme with immo off on a DEAWOO REZZO. It's a hybrid same a LANOS hybrid.
    I make a immo off with immdec3.2 and disconnect immobox but not work.
    Ca you send me the pass for this ?
    ****Lanos_95020 immo off tested gkogkolos****
    Thanks in advance
  16. #13
    FRANCE
    no one to help me?
  17. #14
    publiperro's Avatar
    Apr 2016
    Espaņa
    Quote Originally Posted by gkogkolos View Post
    Bro,
    regards
    hi friend,password please,thanks
  18. #15
    rafal's Avatar
    UK - PL
    Quote Originally Posted by publiperro View Post
    need help
    now my goal is to buy xp-005
    who will help?
