Page 2 of 12 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 172
Thread: vw Polo iaw4
  1. #16
    Czech republic
    Worked THX
  2. The Following 2 Users Say Thank You to carhelp For This Useful Post:
    immokill (7th July, 2017), panos_k (7th July, 2017)
  3. #17
    dragoshu's Avatar
    Aug 2016
    Dacia
    Can I have pass for this DD immo off?
    Regards,
    Dragos
    If I help you dont forget to push thanks button
  4. #18
    dragoshu's Avatar
    Aug 2016
    Dacia
    Quote Originally Posted by pandokrator View Post
    here your immo disable.
    pass on your inbox.
    regards
    Can I use your file >please give the pass
    Regards,
    Dragos
  5. #19
    pandokrator's Avatar
    Oct 2008
    Eu.Gr
    upload your dump m8,
    with file from other ecu you loose VIN and Coding also,
    so must not work on your ecu-car.
    bR
    keep your friends close and your enemies closer
    Golden Section
    The Real ART
  6. #20
    Above sea-level
    Can someone immo off this one?
  7. #21
    konop11138's Avatar
    Your file off
  8. The Following 8 Users Say Thank You to konop11138 For This Useful Post:
    abdulrauf (30th March, 2018), budG60 (16th July, 2017), cole_mcs (18th August, 2018), diga1 (28th February, 2020), djura (21st September, 2018), E82 (2nd February, 2019), javiere (6th March, 2018), pipina (4th February, 2019)
  9. #22
    t77's Avatar
    Poland Lodz
    Hello DK friends I need help with immo off ECU 036 906 034 AH IAW4MV.AH
  10. #23
    Oct 2008
    Eu.Gr
    Default 036906034s immo off
    Quote Originally Posted by budG60 View Post
    here is your file off friend.
    bR
    Golden Section
    The Real ART
  11. The Following User Says Thank You to pandokrator For This Useful Post:
  12. #24
    Mar 2016
    EU
    Default lupo 1.4 16v
    hi need help with immo off or virgin file
    IAW4MV.CE
    036906034CE
    memory is 95080
  13. #25
    Above sea-level
    The immo off worked, but unfortunately the ecu gives throttlebody errors and replacing the throttle body does not help. I found another ecu 036906034D, but need immo off for this one too so please help. I noticed this ecu is iaw4lv instead of iaw4mw, but it is for the same engine code so I hope it will work.
  14. #26
    Mar 2016
    EU
    Thanks for your help budG60
  15. #27
    Oct 2008
    Eu.Gr
    need write back your coding code friend,
    after that all wwork ok
    regards
    Golden Section
    The Real ART
  16. The Following User Says Thank You to pandokrator For This Useful Post:
    dragoshu (17th July, 2017)
  17. #28
    dragoshu's Avatar
    Aug 2016
    Dacia
    hello mate,
    can you help me with immo off on this WW POLO 1.4 MM ECU IAW4MW-S
    036906904 S
    polo-2oo1-17.-07-2017.rar
  18. #29
    Feb 2013
    HI!
    pandokrator You could help me inmo off? IAW4LV.H
    thanks in advance
    Attachment 463816
  19. #30
    panos_k's Avatar
    GR pankar
    Hello dragonshu,
    immo off WW POLO 1.4 MM ECU IAW4MW-S. Pass pm
  20. The Following User Says Thank You to panos_k For This Useful Post:
    dragoshu (18th July, 2017)
