Motor run ok. Thx for panos_k.
panos_k (21st December, 2018)
Hello, I need immo off for this two dump. Both engines with ECU will be swaped from VW polo in skoda felicia. Do I need then cut something in ECU and will that work without cluster?
Tray . pass pm
tomic19 (10th April, 2019)
Hello, I have another one ECU, first two I didnt try yet...
This is Golf IV 1.4 16v, IAW4CV.VO 036906014AN ecu.
I need to remove immo from car Seat Ibiza 036 906 034 AH IAW 4MV 005 4834
2003 year
eeprom 95080
Thanks.
please i need immo off for this Polo 9N. i Came with ecu from another car. i'll attach the original 95080 and ill write in in new ecu.
Every time i connect ecu to the car fuel pump relay continualy cliking and i try julie emmulator with new ecu but did not work. now i want to try immo off with original 95080 dump. Car is not making diag in ecu but gnd and 12V is present. Any help i'd apretiate. Regards
ssemmedo (22nd May, 2019)
Tanks for the file. this one im posting now is the original file from te swaped ecu. the previus one was from the damaged ecu. so if u can make this one as well to try. any way ill write your file and report results. regards
i try the file the car did not start. maybe becouse is eeprom from another ecu. i wait for the secod file to be ready and ill try wit it. thanks
Try with this.
