Page 4 of 12 FirstFirst 123456789 ... LastLast
Results 46 to 60 of 172
Thread: vw Polo iaw4
  1. #46
    Hungary
    Hello,
    Can I help you with immo off?
    Eeprom: 95080
    036 906 034 CP
    IAW4MV.FB
    Seat Leon
    Year 2002
    Kari
  2. #47
    Hungary
    Quote Originally Posted by panos_k View Post
    Hello dragonshu,
    immo off WW POLO 1.4 MM ECU IAW4MW-S. Pass pm
    Hello,
    Pass not work.
  3. #48
    Nov 2011
    Romania
    hy, can you help me to whit immo off file please
  4. #49
    Pass is your pm.
    regards
  5. The Following User Says Thank You to antlio For This Useful Post:
    Tzepy (17th August, 2017)
  6. #50
    Top Poster + Disconnected's Avatar
    Apr 2010
    Liaskovec, Bulgaria
    Default seat leon
    need immo off needed Magneti marelli
    Launch X431, BOSCH KTS200, FGTech Galleto 2, MPPS , Piasini , BDM100 , KWP2000, Lexia, Can Clip, Compact C4, Omega Programer ... soldering iron
  7. #51
    Dec 2015
    Default Immo Off Marelli
    Hi!
    Pls immo off Marelli 4MV
    VW Polo 1.4
    036906034S_ST95080_TSOP_ori.rar036906034S_ST95080_TSOP_ori.rar
  8. #52
    Jan 2011
    Slovenia
    hi
    please help with immo off iaw04mv.dd
  9. #53
    Apsik's Avatar
    Mar 2015
    just behind you
    your solution works perfect, however I can' change codding.
    It is 00071 but should be 00031
    Any advice
    Quote Originally Posted by pandokrator View Post
    write my file and start car without keys.
    bR
    If you find my post helpful please hit Thanks button.
    You can also hit Reputation button if you are kind enough.
  10. #54
    Sep 2013
    Hello
    036 906 034 DD IAW4MV.DD
    Possible to make immo off?
  11. #55
    Sep 2013
    Hello
    Possible to make immo off?org.zip
  12. #56
    Jul 2009
    Hello!
    I have pin code and immo off file Golf BBY.
    Ecu:036 906 034 DD, IAW4MV.DD
    GOLF_BBY_95080_ORI.rar
    Thanks!
  13. #57
    pandokrator's Avatar
    Oct 2008
    Eu.Gr
    Quote Originally Posted by mis View Post
    Hello!
    Thanks!
    no immo off solution from me for that ecu friend.
    only immo 3 can be done,Or when e2p have VIN
    bR
    keep your friends close and your enemies closer
    Golden Section
    The Real ART
  14. The Following User Says Thank You to pandokrator For This Useful Post:
    mis (20th November, 2017)
  15. #58
    Jul 2009
    Thanks for the quick response, maybe pin code?
  16. #59
    Mar 2010
    Timisoara
    Default 036 998 034 D IAW4LV.L
    Hello
    Immo off please for the attached file
    Thank you
  17. #60
    panos_k's Avatar
    Feb 2010
    GR pankar
    Hello, try my file. pass in pm
  18. The Following User Says Thank You to panos_k For This Useful Post:
    clauberty (21st February, 2018)
