Results 1 to 5 of 5
Thread: No signal
    Sep 2008
    Default No signal
    Hi bit new to the boxes, i have a zgemma h2h on cable all the leads are correct gift is in the right place, but i am getting no signal what so ever, could anyone help what i am doing wrong..The flash is wooshbuild if that helps...Please someone help..Been looking but there is not that much information about how to fix it or what could be wrong..Thanks..
    Sep 2008
    please edit your xtras with **** as its a taboo subject.box will only work if you have a live vm feed in correct port and you have setup your cable tuner correctly.
    Sep 2008
    Sorry...I have a live feed from vm, and lead is in the rf port, I have tried all the checks internet fine, just no signal at all, could it be a new cable i need will that help..
    Hadron's Avatar
    Nov 2012
    E. London
    Have you enabled & set up tuner B correctly?
    Menu > setup > service searching > Tuner configuration.
    P&D's Avatar
    Are you getting any channels I.e BBC1/ITV/CHANNEL 4 ? (FTA)
