Hi guys
Im hoping someone can shed some light on this here
Ive put this in ECU section tho may need to be in IMMO
Tho its an ecu problem so i posted here
Was called to a car today
As per thread title
1.2 petrol simos9.1 ecu 93c86
Dash is MM 9s12
so i read dash and ecu
A mate told me pin from dash 06127 and advised the ecu may of corrupted.
So he got me a donor file from same car and ecu
With pin 04698.
So i wroymte this new file and rebuilt ecu and went back to the car
Put dash n ecu back in and turned ignition on
Immo light still flashing which i knew it would
So fired up my vcds
Went into ecu and login11 - entererd 04694 and was accepted.
Adaptation10 channel 050 it said PIN in field 1
so i wrote cars orig pin in test box 06127 and pressed test.
Box 1 said wait then promptly changed to the cars orig VIN with the second half in box 2 or field 2 whatever we want to call them
I clicked save and answered yes to the pop up box asking me if im ok writing these new values.
Then done, go back and closed controller
I turned ignition off like ross tech site says
Waited 1 min and turned ign back on
So i went back into ecu and measuring blocks08
went into the channel that shows vin and immo id
Channel 081 i think.
Its still showing the donor vin :-/
Anyone any ideas ?
Ive manually edited the VIN and immo id into my donor dump and will go try it tomo
But not sure if this will work !!
Help here greatly appreciated
Had similar thing a few months back with a skoda and donor file was great and coded fine.
Dave
P.s
Ill post files up shortly
