Results 1 to 3 of 3
    Nov 2013
    Default Renault Trafic 1.9 Dci body control module, programming?
    Hello all,
    I'll try to make it short. I am sure BCM module failed and looking to get second hand unit, the question is, what's the procedure to make it work? If I'm right, it has to be "cleaned" and then programmed? Is there no other way i.e. swapping microchips? And programming has to be done with can clip only?
    Tried search but nothing clear.
    Thanks for straight forward answers. Please do not reply if you "think" or "may be right", I need this sorted..
    Apr 2014
    swap the eeprom over to the donor uch, make sure the part number and version number is the same as the damaged one
    marsete's Avatar
    Oct 2010
    SPAIN
    hello,program with renault can clip interface,no problem.Regards
