Page 1 of 5 12345 LastLast
Results 1 to 15 of 69
Hybrid View
    mexanico1971's Avatar
    portugal
    Default Renault Clio UCH repair and replacement width new versions
    I People
    I dont know if exist any thread about UCH repair and replacement
    Old versions like Sagem BG or N?1 are not available any more
    S? any one knows any source to buy it ?
    wicth version is use now for replace old ones
    About repair , i see that major problems are solders in PCB parts , not in connectors
    Newbies , wend you want any pass , send PM to the guy , don"t span the thread
    My work is my life ART TECH GARAGE
  2. The Following 7 Users Say Thank You to mexanico1971 For This Useful Post:
    albertros (8th November, 2018), alclot (15th October, 2018), Fresk29 (17th February, 2018), Louislesinge (30th November, 2017), martinracing (4th December, 2017), McDowell (1st July, 2019), racin-snake (4th February, 2018)
  3. #2
    Mar 2010
    BG can be replaced with N2, HG replaced with N3.
    N3 will replace N2.
    N1 seems to only like N1
    Not complete list but a start.
  4. The Following 8 Users Say Thank You to albertros For This Useful Post:
    alclot (15th October, 2018), dt200 (28th December, 2017), Louislesinge (30th November, 2017), Manuelgb (28th October, 2018), martinracing (4th December, 2017), mexanico1971 (15th May, 2017), Stelaras26 (19th November, 2019), titoarg (1st November, 2017)
  5. #3
    Dec 2009
    Prussia
    Quote Originally Posted by albertros View Post
    N3 will replace N2.
    What can replace N3?
  6. #4
    Meat-Head's Avatar
    Quote Originally Posted by TULGEYWOODMAN View Post
    No idea, use stalk function for “Obdmaster” not sure if was posted online or offline
    but he was playing with himself and discovered odd things like no headlights or nor windows
    if you cant find excact unit you need, get chepest off ebay and/or
    ”price up new from dealer” ask for latest part numbers
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
    RAIONEJB (2nd April, 2022)
  8. #5
    Aug 2018
    East Pole
    Did you tried the opposite? HG and N2?
    FREE SOLUTION IN POST #50. READ BEFORE ASKING PASS, YOU LAZY PEOPLE! ASK PASSWORDS ONLY IN PM! STOP THIS "PASS PLEASE" SPAM.
  9. The Following 2 Users Say Thank You to volorucinski For This Useful Post:
    Meat-Head (2nd April, 2022), mexanico1971 (25th May, 2020)
  10. #6
    portugal
    Thank"s for your input
    So if BG can be replace width N?2 why does N?2 have delay after turn key off ?
    I mean I switch off the key, and take it out of the ignition, and engine only 4 seconds later shot off ?
    Any idea ?
    I coded UCH width Clip
    Thank"s in advance
    Brs
  11. #7
    Jan 2010
    Hi, after UCH replace do a ECM reprograming and all will be ok, dont know why but worked all times for me.
    Best regards
  12. The Following User Says Thank You to guerraa For This Useful Post:
    mexanico1971 (18th June, 2018)
  13. #8
    Dunker's Avatar
    Yorkshire
    Solder all caps etc. under black 40 pin connector. Solves 99% of UCH faults.
    Also, for your own reference, from a good UCH measure all components to PCB GND under the connector and write all values down. Will give you an idea if a component or something connected to it is not right. Will save you hassle of removing connector more than once.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  14. The Following 7 Users Say Thank You to Dunker For This Useful Post:
    albertros (14th December, 2023), alclot (15th October, 2018), Louislesinge (4th February, 2018), McDowell (28th June, 2019), Meat-Head (15th November, 2018), mexanico1971 (6th February, 2018), PierreTheron (7th March, 2020)
  15. #9
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    What I can tell you is I've change about 50 UCHs in my life, most of them with original parts, and a lot with used parts.
    You can allaways change Nx for a same grade or higher (N1 instead of BG, N2 instead of N1 etc).
    Another speciall thing is if you got a Clio with engine 1,9 DTI, it needs to be the same UCH because of the antitheft. No other UCHs works for antitheft instead of the original: it happens to me twice ( red light stays on without flashing, it means no comunication UCH=>ECU) and I did not find another solution than removing antitheft from ECU 0 281 010 788 .
    I've tested virgin, copying, all desperate things you can do.
    I think this kind of ECUs have a special protocol.
    Regards,
  16. The Following 6 Users Say Thank You to Louislesinge For This Useful Post:
    dt200 (28th December, 2017), martinracing (4th December, 2017), mexanico1971 (17th March, 2018), PierreTheron (30th December, 2017), runtronics974 (26th May, 2018), Stelaras26 (17th September, 2022)
  17. #10
    Jun 2017
    French Jungle
    By the way I order an UCH to replace BG P8200065817 G1 V4.1 , the replacement from Renault was 82 00 621 763 written N3 instead of BG.
    Regards,
  18. The Following User Says Thank You to Louislesinge For This Useful Post:
    mexanico1971 (26th October, 2018)
  19. #11
    Jun 2017
    French Jungle
    For the same UCH BG P8200065817 G1 V4.1 pulled up from recycle.
    Antitheft light blinking permantly, does not reconise or even see any key i tryed (tested reset and another antena etc).
    Tested continuity beetwen pin8 Black connector 40 ways and SAGEM E34707A OK (near the same connector upper right side, no contact to earth.
    Tryed to replace the chip SAGEM E34707A from another working UCH: Now works fine, can learn the keys again, car starts.
    If some needs electric diagram:
    Regards,
  20. The Following 10 Users Say Thank You to Louislesinge For This Useful Post:
    alclot (14th October, 2018), Col19 (18th November, 2019), karim07 (16th February, 2018), KCSS (26th April, 2019), key90 (25th May, 2021), laurentiudania (13th December, 2019), line44 (7th March, 2023), mexanico1971 (6th February, 2018), PierreTheron (7th March, 2020), runtronics974 (26th May, 2018)
  21. #12
    Dec 2009
    Garage
    Hi.
    I found something and repair this uch without them come back to me.
    It take me a lot of nerves to find this but I wanna to find what can be done and after that solution I repair more then 10 uch and cars work more then 3 years without problems.
    If someone need this ask on pm for password.
    I use picture from 1 post of mexanico1971 .
    And my picture high res. to see how it`s look after repair.
    Soldering is not my best work but in late nihgt hour when I work this can pass.
    Regards
  22. The Following 78 Users Say Thank You to tomo776 For This Useful Post:
    adiagnostyka (14th November, 2019), amor89 (1st January, 2019), anonimusxx (15th March, 2022), Anzelmas (29th February, 2020), AsteveA (5th March, 2020), autel15 (19th November, 2023), bokki (29th October, 2020), cata13 (10th November, 2021), cemar (9th August, 2018), CHIKODIAG (17th December, 2022), chrisgoates (12th April, 2023), Col19 (18th November, 2019), D0k1 (14th September, 2023), Dawid86 (15th September, 2018), Dede1989 (16th October, 2022), denis1hr (21st May, 2020), Doze (18th October, 2023), eeprom241 (19th December, 2018), electro10 (3rd March, 2022), franke232 (25th September, 2018), gentiabazi (20th November, 2018), gerixusyu (10th April, 2019), Gferi (15th October, 2023), giovanniparis (3rd May, 2018), gomarota (23rd March, 2020), janusz21 (7th March, 2018), Jerry 151 (26th January, 2019), jgspnovisad (13th October, 2020), jjrp255630 (23rd October, 2019), jodank (3rd September, 2019), joker01 (16th August, 2020), jolor (11th February, 2020), kalmar123 (23rd November, 2018), KCSS (26th April, 2019), key90 (25th May, 2021), keyzex (8th February, 2019), kobelco (17th May, 2018), kreepyme (17th November, 2021), line44 (7th March, 2023), Louislesinge (20th February, 2018), Lucky Luke (11th October, 2018), lush29 (27th November, 2023), makis44 (5th October, 2018), McDowell (16th November, 2022), metalxp (12th November, 2020), mexanico1971 (17th March, 2018), mffa (9th July, 2019), morfej (21st February, 2018), mvekaz (31st January, 2019), NACER28 (6th July, 2018), neksus (15th November, 2019), nemanja12345 (29th June, 2019), Pali33 (19th August, 2019), panos_k (28th October, 2021), pedro222 (7th November, 2019), PETERALC506 (26th November, 2018), PierreTheron (2nd July, 2018), Plero (24th August, 2023), RAIONEJB (2nd April, 2022), rochinha75 (16th October, 2019), Rollytiberius (19th December, 2018), roybws (25th April, 2022), rtvservis (16th November, 2019), runtronics974 (26th May, 2018), silviuu (8th February, 2019), skcelectronic (5th September, 2019), skyline-GTR (2nd March, 2019), starkey (13th April, 2019), systemlinux (23rd October, 2019), tawaf111 (8th June, 2018), tobyb (30th August, 2019), vince_est (11th March, 2018), whim (25th December, 2018), zeca (14th May, 2020), zefoguete (23rd October, 2019)
  23. #13
    May 2015
    Quote Originally Posted by tomo776 View Post
    Hi.
    Regards
    Password please, tank
  24. #14
    Jan 2018
    Germany
    hi
    anybody has pin out for this module ? i resolder everything on the board.
    in my case i can reed with immo tool eeprom data over obd but i canīt read the hole car only airbag answer???
    car is not starting light window wiper and remote work good. starter only work for 2 sec
  25. #15
    Jan 2020
    Hi Tomo,
    I am interested in your investigation please could you send PW
    Regards
    Steve
