Results 1 to 1 of 1
    Nov 2014
    Turkey / İstanbul
    Default Zed-FULL Key Programmer
    Remote cloning
    Eeprom applications to generate transponder datas and pincodes
    Programming key-remote through OBD-II ports on car for various car brands.
    Zed FuLL is designed to meet all your needs related with electronic side of locksmithing and Immobiliser systems.Zed FULL has 5 different antennas for 125 Khz transponder reading and cloning, reading 13,56 Mhz hotel door cards& tags, measuring 315,433,868 Mhz remote signals, Reading and cloning Holden Commodore remote keys and programming keys for VAG Group cars.Regular updates will keep you at the top and one step ahead from all of your competitors.
    OBD Applications;
    Zed-FULL is designed to extract the pincode automatically from the car through OBD port during key-remote programming procedure. Zed-FULL has VAG(Volkswagen, Audi, Skoda, Seat), Opel-Vauxhall, Renault-Dacia, Toyota-Lexus, Ford-Mazda(Europa, USA, Australia), Falcon, Fiat-Lancia, Daewoo-Chevrolet, Hyundai-Kia, Peugeot-Citroen, Nissan, Proton, Mitsubishi, Subaru, Honda, Holden,Isuzu, Chrysler, Dodge, Jeep, GMC, GM, Renault-Volvo Truck(24Volt) key and remote programming functions via OBD-II port on the car.Hardware Details;
    7inch HD-TFT Touch Screen; With the high resolution and wide screen, you will enjoy using Zed-FULL. Wide screen will allow us to show all details of the applications on the screen like remote key to use during remote cloning, recycling and OBD applications, immo box and board pictures during eeprom applications, transponder types during transponder production, transponder cloning applications etc…
    Zed-FULL has just one OBD-II cable for all OBD-II applications. You won’ t be lost among many types of cables for OBD-II applications anymore.
    Steering wheel holder, will help you during OBD applciations on the car. You may easyly insert Zed-FULL on steering wheel and operate the device using touch screen to program keys and remotes to the car.
    Zed-FULL is designed to have all functions related with immobiliser in one device. So Zed-FULL will meet almost all of your needs for your key-remote programming service.
    Zed-FULL is the unique immobiliser device which supports both 12 and 24 Volt battery installed vehicles. That means trucks also can be programmed with Zed-FULL without need of any additional hardware.
    With Zed-FULL Probe cable, you can also check the voltage of car or remote key batteries. Also with same cable you can check the continuity of the wire connections during eeprom applications or any other applciation you may need to check wire connections.
