Results 1 to 15 of 20
    Default Box Update Advice Needed BEST Box 2017
    With Sly now going Dark I want to move towards VM and update my box.
    1) Ideally something that can have a cable feed (For Normal Channels) and satellite feed (For FTA Channels).
    2) Ideally something that can allow recording another channel while watching different channel.
    3) HD Compatible.
    4) Budget is Flexible around ?300 but consideration will be given to budget versus benefit ratio.
    5) Good to have added features such as KODI, IPTV etc but that's not compulsory
    I am very na?ve with technology so please excuse me for my limited knowledge
    aftermath's Avatar
    Mar 2008
    VU DUO 2, might be a tad more in cost but a superb box, can have 2 duel tuners any combination.
  3. The Following User Says Thank You to aftermath For This Useful Post:
    digicon (18th May, 2017)
    P&D's Avatar
    Quote Originally Posted by aftermath View Post
    Good box........but nothing the OP will buy is plug & play like the openbox
    a lot more in put from the user is needed.........& a lot of reading
    Isn't this box a bit old? How does that compare to Vu 4K? Is there any other box in ?200-?250 mark?
    How many vermin cable inputs does Vu+ Duo 2 support at a time?
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by clarkenuttal View Post
    2 x dual tuners if you want.. so that's 4 tuners ..
    DK Veteran vorlon2257's Avatar
    Sep 2011
    Vorlon Homeworld
    Zgemma-H5.2TC
    I looked but most of them are selling as Dual S2 Tuners (4 inputs) which you referred as 4 Tuners. Will these support 4 Vermin inputs too?
  10. #9
    Quote Originally Posted by vorlon2257 View Post
    Zgemma-H5.2TC
    Thanks I'll read into it. I assume it is a good box?
  11. #10
    Sep 2011
    Vorlon Homeworld
    Yes, the same as all Zgemma's, they do exactly what the Vu+ boxs do at a fraction of the cost you just have to buy an external USB harddrive a 500 gb is more than enough to record as you can't put a harddrive into them. Supported by various images except the openvix image as they class these boxs as clones (which they are not).
    Opena-tv is the main image for the box and is a far better image in my opinion.
    I have 3 Zgemmas myself, a H1 H.2H and H5 they are combo boxs and all working perfect on the opena.tv image 6.0 image
  12. #11
    Can someone confirm if Zgemma H5.2TC can play IPTV too?
  13. #12
    digicon's Avatar
    Simple answer Yes!
  14. #13
    Simple answer Yes!
    So it can play cable and IPTV both at same time? I won't need separate box to play IPTV And Cable?
  15. #14
    digicon's Avatar
    No! you would not even the cheaper H.2H is perfectly adequate for both Cable and IPTV reception and both can be run side by side.
  16. #15
    What image will I need to make IPTV and vermin both work on same box at same time? Is there any instructions available on how to flash and load these images on Zgemma boxes?
