Results 1 to 3 of 3
    Sep 2010
    Default Question about Dish Elevation
    Hi Guys can anyone advise please ?
    When setting the Elevation which in this case is 29.1 from dishpointer using the correct Latitude & Longitude
    Do i set the Dish to 29.1 degrees or Do i set the Motor bracket to 29.1 degrees or both ??
    Thank you
    kidderminster
    Hi Telveskid
    When I set up my system, I set the motor to 30 degrees appox (the markings on the dish are appox), then sent the motor to 1w (sky news) and played with the dish up/down, side to side till I found my best signal, then locked all nuts a bit at a time to make sure that I was locked on. Then go to the sats that you want in turn to check the signal level,(you may have to move the dish a small bit ) to get it to the way that you require.
    Hope this helps
    DEN
  3. The Following 2 Users Say Thank You to den1 For This Useful Post:
    jovie (19th May, 2017), telveskid (20th May, 2017)
    Sep 2010
    thanks for reply
