Cummins CM870 EEPROM and Flash swap help!
Results 1 to 3 of 3
    Oct 2016
    Default Cummins CM870 EEPROM and Flash swap help!
    I have a damaged Cummins CM870 I attempted to swap the EEPROM and Flash chips over to a new module.
    I swapped only the EEPROM and when the module powered up it cleared all data in Flash.
    Is there a checksum or something between EEPROM and Flash that requires they both need moved together?
    Junior Member adftuning's Avatar
    May 2017
    Bilbao. Basque Country
    is not a checksum but you need to change the flash too because software version should be different.
    if you dont know how to do contact me and i will tell you how to do.
    regards
  3. The Following User Says Thank You to adftuning For This Useful Post:
    toshor (21st May, 2017)
    Oct 2016
    Any ideas?
