Results 1 to 4 of 4
Thread: Skoda felicia
    Croatia
    Default Skoda felicia
    Hello, I have ECU from skoda felicia 1.3 LXI
    ECU is bosch 0261203544, eeprom 27c512. Here is original dump in atachement.
    I need two maps for this ECU, first map for original motor and second map for race (CUP) engine (biger valves, port and polish head, racing camshaft, bigger compression ratio and bigger throttle body).
    RPM limiter is now on 6200rpm and on both maps I need 7000rpm.
    If someone can do this two maps please let me know.
    ori-eprom.zip
    Croatia
    Can anyone help?
    Sep 2013
    I will
    write me *Removed Email Address...
  4. The Following 2 Users Say Thank You to xxttcc For This Useful Post:
    Mezz_cro (1st June, 2017), tomic19 (1st June, 2017)
    Aug 2011
    Try contact http://www.cimbu.cz/en/index_en.php ... he won't make you file (few years ago want make mod only on ECU) I send him ECU. He make me very good job.
    moderator: I'm not making advertisment ... if post is not OK please delete it
    regards
  6. The Following User Says Thank You to pipina For This Useful Post:
