i have same situation in past,,,,solved with avdi !! trough dump i think is imposible !!
hello friends
after reading cas3 eprom for bmw x5 e70 the car start but gear cant unlock
after scaning the egs it show immobiliser active
in egs in the cas no dme/egs synchro
i ttry with fvdi toread egs synchro and got the file attached
attached the cas eprom and the egs synchro
can we repair my file?
thanks in advance
Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
i have abdi how did u solve it ?
genius AVDI with egs sync option if you have that licenece!!this is posible only if its 6 gear
http://shop.abrites.com/index.php?ro...product_id=218
You have both ISN erased, from EGS...
Only by reading EGS and DDE to pull out ISN...
You need dedicated tools for this job...
Have you any backup of your Ori dump?
the car start normally but cant move the gear selector can.t move as we read the gear synchro can we repair the cas data?
manualy nope,,,is not posible,,,,only trough obd egs/dde syncronisation
ok and obd through what progrMer is it possible for sure ?
if is 6g than is avdi original one ,,,if 8g than explorer!!! and one more question what tool you use for cas reading ??
doctore (21st August, 2018)
if its 6g or 8g the chinese explorer can do it ?? i was reading it using r270
