Results 1 to 10 of 10
    Sep 2011
    Default Scoda Fabia long coding ABS8.2 6R0 907 379 S
    Hello, anyone can help me calculate long coding for this auto?
    My log:
    Friday,19,May,2017,13:38:09:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.10.7.0
    Data version: 20130802
    VIN: TMB1SB5J7B3133108 License Plate:
    Chassis Type: 5J (5J - Skoda Fabia (2007 > 2010))
    Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
    Address 01: Engine (J623-CAYA) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 NG HW: 03L 906 023 LK
    Component: 1,6l R4 CR td H33 8372
    Revision: --H33--- Serial number:
    Coding: 00114016000400080000
    Shop #: WSC 13765 031 00050
    ASAM Dataset: EV_ECM16TDI02103L 003003
    ROD: N/A
    VCID: 78FF0E6BC32690DEB5D-802D
    No ASAM data for: "EV_ECM16TDI02103L" (VW36 *)
    5 Faults Found:
    6260 - ROD - Unknown Error Code
    - 00 [032]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 255829 km
    Date: 2067.14.14
    Time: 03:03:55
    7332 - ROD - Unknown Error Code
    - 00 [032]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 255848 km
    Date: 2000.00.00
    Time: 00:00:00
    6086 - ROD - Unknown Error Code
    - 00 [032]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 255848 km
    Date: 2071.14.28
    Time: 00:47:34
    6068 - ROD - Unknown Error Code
    - 00 [032]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 11
    Mileage: 255848 km
    Date: 2071.14.28
    Time: 00:47:39
    9861 - ROD - Unknown Error Code
    - 00 [032]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 255848 km
    Date: 2071.14.28
    Time: 00:47:36
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS80.lbl
    Part No SW: 6R0 907 379 S HW: 6R0 907 379 AB
    Component: ABS8.2 front H03 0001
    Revision: --------
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 13765 790 00050
    VCID: 4E9388B31D22FE6E4F1-801B
    1 Fault Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 4
    Reset counter: 87
    Mileage: 256475 km
    Time Indication: 0
    Date: 2009.14.13
    Time: 12:08:10
    Freeze Frame:
    Hex Value: 0x0005
    Hex Value: 0x0000
    Hex Value: 0x1213
    Hex Value: 0x149A
    Hex Value: 0x00FF
    Hex Value: 0x007F
    Hex Value: 0x7F00
    Hex Value: 0x0000
    Address 08: Auto HVAC (J301) Labels: None
    Part No SW: 5J0 820 045 C HW: 5J0 820 045 C
    Component: Man AC 02 0101
    Revision: 0003S 02
    VCID: 2541171F2C14DD36DEB-8070
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
    Part No SW: 6R7 937 087 M HW: 6R7 937 087 M
    Component: PQ25 BCM H30 0555
    Revision: -1------ Serial number: --------------
    Coding: 24980B3808C92400922008002C2B08800000400F6000000002 0000000000
    Shop #: WSC 20470 456 96297
    VCID: 4E9388B31922FE6E4F1-801B
    Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 002 3210
    Coding: 020000
    Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 002 3210
    Coding: 020000
    Subsystem 3 - Part No: 5J0 951 172
    Component: DWA-Sensor 03 03 1109
    Subsystem 4 - Part No: 1K8 951 605 A
    Component: LIN BACKUP HORN H11 H11 9004
    Subsystem 5 - Part No: 5J0 951 172
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10AirbagT20 H09 0020
    Revision: -------- Serial number: 003GX00BJLU4
    Coding: 003230
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_SE25.rod
    VCID: 4A9B84A3ED4AD24E139-801F
    Subsystem 1 - Serial number: 3495RRB40530974O8PNQ
    Subsystem 2 - Serial number: 3505RRB404P07S8SJHCF
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5J0 920 800 J HW: 5J0 920 800 J
    Component: KOMBI H07 0114
    Serial number: 00000004834656
    Coding: 120200
    ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01013
    ROD: EV_DashBoardUDSJCIPQ25_SK25.rod
    VCID: 2C57E23B47FEEC7E015-8079
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R7 937 087 M
    Component: GW-K-CAN TP20 H30 0555
    Revision: -1------
    Coding: 002000
    Shop #: WSC 00000 000 00000
    VCID: F0EFB64B2356489EFDD-80A5
    Address 25: Immobilizer (J285) Labels: 5J0-920-xxx-25.clb
    Component: IMMO H07 0012
    Serial number: 00000000000000
    ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
    ROD: EV_ImmobUDSJCIPQ25_SK25.rod
    Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 10110
    Shop #: WSC 13765
    VCID: 2F6DF537EAE89766247-807A
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5J0 035 152 A HW: 5J0 035 152 A
    Component: Radio H08 0006
    Revision: R0000000 Serial number: SKZAZ6K0431620
    Coding: 050002000006
    VCID: 204F060B3336381EADD-8075
    End ---------------------------------------------------------------------
    Saturday,20,May,2017,10:04:48:62939
    Chassis Type: 5J (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 56
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    ROD: N/A
    5 Faults Found:
    - 00 [032]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 255829 km
    Date: 2067.14.14
    Time: 03:03:55
    - 00 [032]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 255848 km
    Date: 2000.00.00
    Time: 00:00:00
    - 00 [032]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 255848 km
    Date: 2071.14.28
    Time: 00:47:34
    - 00 [032]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 11
    Mileage: 255848 km
    Date: 2071.14.28
    Time: 00:47:39
    - 00 [032]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 255848 km
    Date: 2071.14.28
    Time: 00:47:36
    Revision: --------
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 6
    Reset counter: 189
    Mileage: 256475 km
    Time Indication: 0
    Date: 2009.14.13
    Time: 16:30:06
    Freeze Frame:
    Hex Value: 0x0005
    Hex Value: 0x0000
    Hex Value: 0x1213
    Hex Value: 0x14A3
    Hex Value: 0x00FF
    Hex Value: 0x007F
    Hex Value: 0x7F00
    Hex Value: 0x0000
    Revision: 0003S 02
    2 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 127
    Mileage: 256475 km
    Time Indication: 0
    Date: 2009.14.13
    Time: 14:28:11
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 127
    Mileage: 256475 km
    Time Indication: 0
    Date: 2009.14.13
    Time: 14:28:11
    Coding: 020000
    Coding: 020000
    Coding: 003230
    Coding: 120200
    2 Faults Found:
    13893632 - Function Restricted due to Insufficient Voltage
    U1400 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 127
    Mileage: 256475 km
    Date: 2073.14.13
    Time: 14:41:56
    13635840 - Supply voltage
    U1011 00 [008] - Voltage too Low
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 127
    Mileage: 256475 km
    Date: 2073.14.13
    Time: 14:41:56
    Revision: -1------
    Coding: 002000
    Coding: 10110
    Shop #: WSC 13765
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 127
    Mileage: 256475 km
    Time Indication: 0
    Date: 2009.14.13
    Time: 14:43:26
    alektkac's Avatar
    Mar 2016
    Украина
  3. The Following 2 Users Say Thank You to alektkac For This Useful Post:
    giani03 (14th April, 2019), yary1 (27th May, 2017)
    Jul 2016
    Vilnius
    try this coding:
    100200C1007000B50A2600E200D900000000
    * MK100
  5. The Following User Says Thank You to hid3 For This Useful Post:
    wiatajek (24th May, 2017)
  6. #4
    Sep 2011
    error 22 code rejected
    Jul 2016
    Vilnius
    How about this one:
    400100DB007000B5022600E200D900000000
    * MK100
  8. The Following User Says Thank You to hid3 For This Useful Post:
    salkapone (25th May, 2017)
  9. #6
    Sep 2011
    Work ok thank you :-)
  10. #7
    Default Fabia II , long encoding ESP8.2i front.
    Please, I need to help recover the long encoding for the ESP8.2i front. ?KODA FABIA II 2010 VIN: TMBFH65J3A3155276
    Thank you very much for your help
    LOG:
    Wednesday,19,July,2017,07:47:51:27556
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 17.1.3.0
    Data version: 20170320 DS267.7
    www.Ross-Tech.com
    VIN: TMBFH65J3A3155276 License Plate:
    Mileage: 144460km-89763mi Repair Order:
    Scan: 01 03 08 09 10 15 17 19 25 44 56 69 77
    VIN: TMBFH65J3A3155276 Mileage: 144460km-89763miles
    01-Engine -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    69-Trailer -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine (CGP) Labels: 03E-906-033-AZQ.lbl
    Part No SW: 03E 906 023 AC HW: 03E 906 023 AC
    Component: SIMOS91 1.2l 4V 5288
    Revision: --H05--- Serial number:
    Coding: 0000071
    Shop #: WSC 13765 790 00051
    VCID: 60CB9D7EB028074189-515A
    Readiness: N/A
    Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
    Part No SW: 6R0 907 379 AA HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0003
    Revision: --------
    VCID: 7DF5C40AE09ACAA982-8028
    3 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 174
    Mileage: 144463 km
    Time Indication: 0
    Date: 2011.12.10
    Time: 00:12:50
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0002
    Hex Value: 0x3013
    Hex Value: 0x148B
    Hex Value: 0x00FF
    Hex Value: 0x7F7E
    Hex Value: 0x7FF9
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 174
    Mileage: 144463 km
    Time Indication: 0
    Date: 2011.12.10
    Time: 00:12:50
    00493 - ESP-Sensor Unit (G419)
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 174
    Mileage: 144463 km
    Time Indication: 0
    Date: 2011.12.10
    Time: 00:12:50
    Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
    Part No SW: 5J0 820 045 B HW: 5J0 820 045 B
    Component: Climatic 12 0670
    Revision: 0003S 12
    VCID: 2443D16E27B05B61AD-8070
    Part No SW: 6R7 937 086 F HW: 6R7 937 086 B
    Component: PQ25 BCM H10 0017
    Revision: -3------ Serial number: 1002430401
    Coding: 64980B3808010000002000003E0A08C20040400F6000000000 00
    Shop #: WSC 22675 401 00051
    VCID: 46876BE6F1CC497193-8012
    Serial number: --------------------
    Coding: 020000
    Coding: 020000
    1 Fault Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
    011 - Open Circuit
    Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb
    Part No SW: 5J0 919 475 HW: 5J0 919 475
    Component: PARKHILFE 4K H10 0002
    Revision: --H10--- Serial number: 76241013204530
    Coding: 110002
    Shop #: WSC 29050 260 82294
    ASAM Dataset: EV_SK25XParkiAssis2 S01002
    ROD: EV_SK25XParkiAssis2.rod
    VCID: 72EFE736A5C485D1EF-8026
    Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
    Component: VW10AirbagT10 H09 0018
    Revision: -------- Serial number: 003DW00EZ0NY
    Coding: 003130
    ROD: EV_AirbaVW10BPAVW250_VW31.rod
    VCID: 428F77F6D5E47551BF-8016
    Crash sensor for side airbag: driver side:
    Serial number: 3496GRB4023CU8L2U3BU
    Crash sensor for side airbag: front passenger side:
    Serial number: 3506GRB4033DQ54P741Y
    Part No SW: 5J0 920 840 E HW: 5J0 920 840 E
    Component: KOMBI H15 0206
    Coding: 110A00
    Shop #: WSC 13765 031 00051
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_A04_SK25.rod
    VCID: 2B513A52426E94196C-807E
    Part No SW: 6N0 909 901 HW: 6R7 937 086 B
    Component: GW-K-CAN TP20 0017
    Revision: -3------
    Coding: 232200
    VCID: 70EBED3EA3C8B7C119-8024
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H15 0206
    Coding: 000000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
    ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
    VCID: 6ADFFF568D144D1157-803E
    Coding: 11240
    Shop #: WSC 13765
    VCID: 2F692E42EA76E83940-807A
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
    Address 56: Radio
    Cannot be reached
    Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: Anhaenger H07 0070
    Revision: 3A001001 Serial number: 00000129903169
    Coding: 410D000100000000
    VCID: 306B2D3E6348F7C159-8064
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
    Component: TELEFON H05 0440
    Revision: 1B001001 Serial number: 00007667946239
    Coding: 0700000000010110
    ASAM Dataset: UHVNA A01007
    ROD: UHVNA.rod
    VCID: 326F27366544C5D12F-8066
    1 Fault Found:
    9457427 - Left audio channel for speech/telephone
    B104F 13 [009] - Short to GND
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 174
    Mileage: 144463 km
    Date: 2017.07.19
    Time: 00:02:58
    End-------------------------(Elapsed Time: 02:17)--------------------------
  11. #8
    Jul 2016
    Vilnius
    You might want to try this one:
    400100DB007200B7022700E900D700000000
    * MK100
  12. #9
    Thanks for the help, but unfortunately the coding is not accepted. Error 22.
  13. #10
    Nov 2010
    help me calculate long coding skoda fabia
    Control Module Part Number: 6R0 907 379 S
    Component and/or Version: ABS8.2 front H03 0001
    Software Coding: 000000000000000000000000000000000000
    Work Shop Code: WSC 13765
    VCID: 4E92E39C1D03C13648-801A
    Advanced Identification
    Identification: BPA-085
    Revision: --------
    Date: 24.06.11
    Manufacturer number: 0031
    Test stand number: A300
    Flash Status
    Programming Attempts(application): 0
    Successful Attempts(application): 0
    Programming Status: 00000000
    Flash Date: 0000.00.00
    Flash Tool Code: 00000 000 00000
    Misc.
    Hardware number: 6R0 907 379 AB
    Workshop System Name: J104
    VCDS Info:
    Labels: 6R0-907-37X-ABS80.LBL
    VIN: TMBJJ25J0C3034716 License Plate:
    Chassis Type: 5J-SK25 (6N0)
    Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 LK HW: 03L 906 023 LK
    Component: 1,6l R4 CR td H33 9971
    ASAM Dataset: EV_ECM16TDI02103L906023LK 003008
    ROD: EV_ECM16TDI02103L906023LL.rod
    VCID: 7AFA7F4CFD0BBD96C4-802E
    Readiness: 0100 0000
    Revision: --------
    2 Faults Found:
    03306 - Coding Not Valid
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 190
    Mileage: 248417 km
    Time Indication: 0
    Date: 2003.14.08
    Time: 00:11:13
    Freeze Frame:
    Hex Value: 0x0001
    Hex Value: 0x0000
    Hex Value: 0x1227
    Hex Value: 0x149A
    Hex Value: 0x00FF
    Hex Value: 0x007F
    Hex Value: 0x7E00
    Hex Value: 0x0000
    000 - -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 150
    Mileage: 248417 km
    Time Indication: 0
    Date: 2003.14.08
    Time: 00:17:16
