Is there a viewing card in the box
Is it a vm box ............Paul
Hi I got 3 virgin feeds coming into my house , don't know if any of them are actually "live" have connected a 2nd hand box Samsung box to 1 of them feeds and it jus shows "starting up" on the screen , is this indicative that the feeds are not live , or is it a box problem
PAUL
You can not conclude from just that... you need to check first if the 2nd hand box is set for your area (netid correct) before you can go further...
Is there any other way to check if the virgin cable feed is "live" ? Without a working box ?
Many thanks
gc1966 (27th May, 2017)
To check that the lines are live, just plug the tv into the virmin line and you should be able to get BBC, ITV and similar. At least that should be the case unless things have changed.
Sent from my crystal box, using my cat's whisker.
cannot do that anymore since digital, but wot you can do is go into EM on the box that should tell you wot the sig level's are coming in at........................c
A LITTLE THANX GOES A LONG WAY
