Results 1 to 7 of 7
    metalik's Avatar
    Mar 2012
    Default W210 EZS problem
    Hi all i have problem with W210 ezs. The old key stop working i make new key but it cant synchro, red led blinking. I read 2 mcu 1H52A, i think problem is eprom. Someone can fix dump?
    w210 1h52.rar
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by metalik View Post
    w210 1h52.rar
    what tool you use for reading ??? dump from mcu1 is corrupted...
    many thanks to friend kevfield
  3. The Following User Says Thank You to daxxer For This Useful Post:
    rokibar (27th May, 2017)
    Jan1980's Avatar
    Nov 2014
    I repaired the dumps ! I think, you have also a problem with your EIS itself. Buy a donor EIS with same partnumber and write the repaired files to the MCU?s. There are not only eproms in the mcu?s. These MCU?s have ROM. You are not able to read and write new MCU?s. So, get donor EIS and write repaired eproms back. Press THX and REP...
    w210repaired.rar
  5. The Following 4 Users Say Thank You to Jan1980 For This Useful Post:
    daxxer (26th May, 2017), doctore (13th June, 2017), metalik (27th May, 2017), rokibar (27th May, 2017)
  6. #4
    metalik's Avatar
    Mar 2012
    hello, i write repaired dump from Jan1980 to the new EIS and its working. Thx a lot for help
    metalik's Avatar
    Mar 2012
    Hello new W210 and new problem, key stop working, i make new key car start but dont work central locking, blinker. I read again mcu 1 and 2, i think somethink is corrupt in eprom. Semeone can help me ?
    w210 .rar
  8. #6
    narkeleptk's Avatar
    May 2017
    USA
    w210 .rar
    looks ok to me.
    Sounds like a bad/bridged solder joint or corrupted flash possibly. Both will cause issues with canbus like you listed.
    In my experience if key turns switch its not going to be an issue in the eeprom data.
  9. #7
    metalik's Avatar
    Mar 2012
    Hello i solve my problem. I make new key from mcu2 and ewerythink working. 😀
    Wysłane z mojego Redmi Note 3 przy użyciu Tapatalka
