That is how they come new from factory completely blank. They need to be configured with a suitable programmer.
I got some PCF7941 chips from china.
They are all locked, only ID is readable, and all chips have the same ID : "55 55 55 55"
The seller said, till now nobody has complained. (and there are really no negative reviews for the product)
Am I missing something ?
I tried everything. Put even the chip on original key PCB. Nothing has worked.
Any idea ?
Why would factory make locked chips ?
I think he means format or "image generate" with tango / tmpro.
I havent bought pcf7941 for long time but the ones ive had never said locked. always unlocked if memory serves.
You can write this chips with vvdiprog or pcfprogrammer, need eprom and erom files
Or unlock original chip, no need new
Duracell2 (26th May, 2017), Faraday (28th May, 2017), TERMINATOR1000 (29th May, 2017)
ecuremap1 (29th May, 2017)
The pcf7941 come without an individual I'd programmed by default it's 555555 and can be edited. This is why the Chinese can use them to emulate pcf6946/7 by changing the id of the chip to one that corresponds to those chips. From memory it's the last byte of the id that identifies the type of pcf by changing this you can change what an rf programmer identifies the type of chip it is.
Until the chip has a valid id an rf programmer cant identify it properly and as a result you can't write to it.
TERMINATOR1000 (26th May, 2017)
Hello my friend
with vvdiprog or pcfprogrammer can you read eprom and erom files on transponder for duplicate this ?
OR you have to have these files (so buy them!)
to solitaire !
Read the PCF7941 key use Hitag2 reader.
If one green block and 7 red block, cannot use
If 8 green block, can use, just load your key data into the key. You can use Hitag2 programmer to load the key data.
I know. Only first block is green (4 bytes for chip ID).
The rest is red
TERMINATOR1000 (28th May, 2017)
