Results 1 to 2 of 2
    May 2017
    Default DM800HD (Clone) OpenPli - Can not install .ipk?
    I recently updated my DM800HD PVR clone from SSL82 to SSL84b
    Then flashed the box with "openpli-enigma2-4-dm800-20160415-Jasper-20160416.nfi"
    All went well
    Set up, Scanned Channels, etc, all good
    Then it comes to loading OSCAM
    Internal Server shows no listing
    So i download "enigma2-plugin-softcams-oscam-11245-linuxsat_openpli_mips32el.ipk"
    Try USB method, install extensions, installation looks like it works, then installed 0 of 0
    Tried FTP method in VAR/VOLITILE/TMP, manual instal, it also fails
    Tried FTP, then use Telnet commands to install, it also fails
    I have tried with a different version of OSCAM with same results, all failed.
    What is the trick with the OPEN Pli image??
    Why is this being so painful?
    Thank you
    toysoft's Avatar
    Nov 2008
    mips32el.ipk are not for DM800HDpvr boxes, you need to get and install mips32el-nf.ipk files
    TS
