Ok friend I'll explain it to you in a drawing.
WINNER THE LOSER
javicorne (14th June, 2017)
Thank you. I have the chip located, but I would like know which is the PIN number 1 in the chip.
You shoud also improve your googling skils , it can help you a lot in any kind of job, especeally jobs like this...
for example - http://lmgtfy.com/?q=24c16+pinout
You need to practice and study hard to do this.
If you don't know which is pin 1, how are you going to do to unsolder and solder the eeprom?
If i help, d'not forget to press thank button!!
I'm just learning, I trust I can do it anyway I will shar my experience to be used by other members.
Thank you so much.
Seems like everything was done properly, here my first dump, where the mileage was modified to 60000. Of course the test was done in a pre owned BCM, since I was afraid to damage something in my first time.
As far as I know this is the only step to folow in my car, since the odometer should take the information from the BCM, I'm right?
Now I have to do it in my car, let's see when I get some free time...
you learn fast...You use brian.exe.....................
WINNER THE LOSER
antenor (14th June, 2017)
Your dump show 60000.
Yes, 60000 is the new value, the old one was different.
Anyone know if change the value only in the BCM is enough in my car?
bcm enough..............
Thank you mate. I'll try it
For the information who want do it, finally the job was done through the Diag plug.
Thanks to all.
