Hi friend, i search egr off for my vito Mercedes 2200 cdi edc16c2 sw:1037366515 . I search egr with disconnect sensor. Tested solution if is possible.
Thanks in advance
Thanks in advance
ADF Tuning CHIPtuning/ECOtuning/DSGtuning
100%tested DPF EGR ADBLUE LAMBDA TVA VSA EVAP CAT DTC errors delete
Professional chip tuning development
Car, Bike, Agriculture, Bus, Truck, Marine
eiemax (29th May, 2017)
What problems does the car have? What Error Codes. I looked at the file in it and there is no EGR. Does this car have no EGR system?
This car have egr. Thanks
stanislav georgiev (29th May, 2017)
hi try this pass pm
Not work. anyone can help?
Maybe if you explain something better than "not work" someone can go deeper and try to help.
maajkii (29th May, 2017)
eyemax u need close egr phisical in this case
i have solution for this 16c2...contact me if you still need
Not work, egr move in normal mode, is not close
I do not know if it will work but if you want you can try
