Upload your readed file mate, then anyone can try to help you...
I bought an Astra 2011 which had had no proper servicing for a long time now at 195,000 miles , DPF is NOW BEYOND FULL and will not regenerate anymore , Causing many different running problems.
No problem for me to take off DPF and remove honeycomb / weld back together ,
I Have downloaded ECU Binary with MPPS V18 (which is great)
Can someone suggest good program to remove DPF from Binary ? or can do this for me ,
Car details are ASTRA 1.7 16v CDTI 110hp 2010on DENSO AX36 CAN
ENGINE TYPE : A17DTJ
ECU TYPE : DENSO 0100
Last Programming date : 08/05/2014
Any Help would be GREAT ! Many Thanks
*Please use Thanks and give Reputation if I helped you*
