CAS 2 dead? e90 won't start pls help
    Feb 2017
    Default CAS 2 dead? e90 won't start pls help
    Dears
    After the mileage correction dash (new epprom) + cas 2 e90 won't start. only services information, steering block. Pls help:1087:
    Any recommendation? cas is dead? flash? What i should do?
    Thanks in advances
    item: r270plus
    pls find about Cas 2 (white) 6.943.791
    IC: 2911A
    May I ask you about dump to Cas 2?
    Backup from Cas 2 below
    May 2017
    leverpol
    re flash heeee*
    Feb 2017
    flash help? Could you send flash?
    Inpa not connect in standard mode (engine blank is not black during the connection process)
    pls find list of errors what i see
    CAS: A121 61
    A118 60
    KOMBI:
    9316 60
    A3C0 60
    A3C3 60
    A3C7 60
    9319 62
    931A 62
    give me flash
    lechus111's Avatar
    Jan 2014
    Jun 2017
    BALKAN
    if you have ignition just use winkfp and flash it by obd
    if you dont have ignition finde used cas put eprom in to have ignition and flash it via obd
  7. The Following User Says Thank You to kono For This Useful Post:
    losevarahmed (31st March, 2022)
