Results 1 to 2 of 2
    Nov 2012
    Default SSL to tell what it is
    evening i have a dm800 it was a problem when i bought several years ago.
    i decided to update the image on line which resulted in the dreaded no ca found.
    i managed to sort it out (more by luck) using windows ME .if i remember correctly the main problem was withth e image and finding one to match the ssl which was 7? .
    Any way the box has worked fine for years until i decided to update the box.
    which ended in the same situation as years ago no ca found.Took a while found the drivers for the null modem for windows 10 and a patched dream up that allowed me to talk to the box,
    so loaded patched and unpatched images .same result cr2 unstable.
    i would appreciate help in bring the box back to life with iptv if possible/
    toysoft's Avatar
    Nov 2008
    Now there is an easier tool, it's called JapharFlasher (it's a DreamUp Universal tool that works with ALL Sim and boxes, original and clones),
    TS
    Quote Originally Posted by daimes View Post
