DM520HD SuperSim Japhar : PowerSat 1.1b1 2017.04.28
Power-Sat-1.1b1-dm520-20170428090208.rootfs.tar.xz
4.3.1r3
- added Durline UCP20 V2 (with different SCR frequencies) to supported unicable switches
- increase unicable delay after switch command
- ServiceList: refresh every full minute while open
- GraphMultiEpg: fixed wrong prime time (patch from dre ... thanks!)
- VirtualKeyboard: fixed layouts with more than 5 lines and add ru_RU
- CeC:
- minor fixes
- fixed "tv power on" detection in some cases (Samsung and probably others, too)
- added reset option to CeC-Setup, set's all options to default
- fixed bus errors when trying to acces files on dead storage (e.g. network mounts)
- fixed some issues with widget animation enabling/disabling
- fixes broken "blinking" and
- fixes custom animations for widgets when defaults are disabled
- properly fixed issues with eListBoxPythonMultiContent and animations
- raise RLIMIT_NOFILE to 8k min (soft & hard) on enigma2 startup
(fixes ION-related crashes when a lot of pixmaps are being cached/held)
- restate some strings
update dm820/dm7080 hardware drivers
- CEC:
- add some debug output and make debug output better readable
- some CEC fixes and improvements
- si2166b/si2169c:
- add auto DVB-S/DVB-S2 delivery system handling (like DVB-T/T2)
- fixed possible deadlock on blindscan
- si2166b: firmware update
- si2169c:
- fixed DVB-T(2) 5V switching
- add better readable debug output
- disable 5V when tuner switches to sleep
- fixed possible rf_switching problem
update dm52x/dm900 hardware drivers
- CEC:
- fixed lame CEC bus in standby
DM900:
- si2166b/si2169c:
- si2169c:
MEGA :
PHP Code:
https://mega.nz/#!BMkQDIpK!zWhsMnRwUDRY1BkSxv2jFrD476oMZ8Gpf5dfDGrC3LU
