newest zgemma?
Results 1 to 15 of 20
Thread: newest zgemma?
    Top Poster tazzuk2009's Avatar
    Default newest zgemma?
    hi all.
    what the newest cable zgemma box ? i brought a zgemma star lc. but had nothing but problems with it. ending up sending it back to get another but that alos went back.
    maca's Avatar
    Feb 2009
    liverpool
    Some people are best steering clear of E2 boxes truth be known
  3. The Following 3 Users Say Thank You to maca For This Useful Post:
    grahampaull (2nd June, 2017), happy_highlander (1st June, 2017), tazzuk2009 (5th June, 2017)
    Quote Originally Posted by maca View Post
    how come? because of reliability? or ?? and what other cable box would you suggest
    happy_highlander's Avatar
    Aug 2010
    Quote Originally Posted by tazzuk2009 View Post
    Reliability is great. Almost all other problems are user related hence some people should stay away
    Sent from my SM-G935F using Tapatalk
  6. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    maca (1st June, 2017), tazzuk2009 (5th June, 2017)
    Zgemma H5 is a great piece of equipment. Load Whooshbuild image on it and it would work flawlessly
  8. The Following User Says Thank You to clarkenuttal For This Useful Post:
  9. #6
    DK Veteran lincsat's Avatar
    Jun 2008
    Latest would be the H3.2TC, released just after the H5.2TC. They are identical except the H5 will playback video compressed with the H265 codec. They have a single Sat and a Twin Cable tuner.
    They work really well when setup properly. Biggest issue is user error.
  10. The Following 3 Users Say Thank You to lincsat For This Useful Post:
    maca (2nd June, 2017), Mee?kat (7th June, 2017), tazzuk2009 (5th June, 2017)
  11. #7
    thanks all for the info. i have a new box on the way..
  12. #8
    hi have you got a link for this build.. for a zgemma h2h
  13. #9
    P&D's Avatar
  14. The Following User Says Thank You to P&D For This Useful Post:
    tazzuk2009 (28th June, 2017)
  15. #10
    will any of these zgemma boxes have Support for internal HDD or are they all external hdd we have to install only thing putting me off getting one.
  16. #11
    digicon's Avatar
    Quote Originally Posted by tab99_uk View Post
    External Only, you would have to 'UP' your budget slightly if you want a receiver that supports internal hard drive. the Technomate E2 series (some of them) receivers take an internal drive
    TM-Nano-SE M2 Plus as an example
  17. #12
    Jun 2008
    The H3 and H5 Zgemma do support internal SD cards, well in a slot in the side. Only PLi fully support the SD card but you can get them working with ViX if you format them in a PC with the free Partition Wizard tool and let them automount.
  18. #13
    Quote Originally Posted by lincsat View Post
    The H3.2TC you mention looks great value actually, i had a look at one or 2 online and one of the pictures i got to see the rear and there is only one x rf in and a loop out although the description clearly states it has 2x dvbt tuners, i,m wondering if the photo i seen is an old stock photo or something.
    It had the lnb input aswell ofcourse but i couldn't see a 2nd cable tuner on the box i looked at.
  19. #14
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by Mee?kat View Post
    It will probably have an internal splitter for the cable feed, so only 1 connector required.
  20. The Following User Says Thank You to Hadron For This Useful Post:
    Mee?kat (8th June, 2017)
  21. #15
    Jun 2008
    Both the H3 and the H5 have a twin cable tuner with a single input and no loop output. They also have a single Sat input.
  22. The Following User Says Thank You to lincsat For This Useful Post:
