Results 1 to 14 of 14
    Jan 2016
    Default CRAFTER EDC16CP34 SMOKING WHITE
    Help me to find the map in this file
    or damos for this
    thank a lot
    I m new in vag
    Sep 2015
    You sure that isn't mechanical problem? Always white smoke cold/hot?
    Wysłane z mojego SM-G920F przy użyciu Tapatalka
    Aug 2015
    injectors problem probably
    Jan 2016
    after someone sand pit in the filter the smoking white came
    injector is the problem 100%
    compresion...?
    DK Veteran elchip's Avatar
    EU
    Did you maked DPF OFF ?
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
    maybe water cooler radiator????
    Junior Member FlameFenix's Avatar
    Nov 2010
    Bulgaria
    if u remove dpf it will smoke more.. i think the problem is injector but i'm not 100% sure
    Jun 2017
    check injector
    Feb 2013
    HI!
    White smoke is injectors
    Jun 2012
    Hi after you make dpf off and check injectors and still the same.... just put new lambda and everything will be okay! Had two crafter's like this one
  13. #13
    Mar 2017
    RO
    Hello, I have a VW Crafter 2.5 TDI engine code BJL, with the following problem, the N75 valve is not commanded by the ECU to open enough so I do not have enough vacuum at the turbocharger actuator, the vacuum at the actuator is 400 mbar, instead of 700 mbar.
    I mentioned that there are no vacuum losses on the hoses, I replaced the N75 valve with a new one, I monitored the control voltage of the N75 valve on the oscilloscope and it is noticed that the problem is at the ecu, we inspected the ecu and did not detect cold soldering, I think The problem is soft.
    I request an original sheet for EDC 16CP34-4.4
    074 906 032 BA
    Thank you
  14. #14
    Apr 2016
    holland
    try to look at vacuum hose if hole is not dirty less vacuum use a small drill i hat this coplle off times alreday
