JorgePeugeot (4th June, 2017)
Get China ZED and read pin from transporder , some models China Zed bull read pin in key , or go to a Key store
If you are Tuga you have Autocom or other and you add the key
Next Time give all info you can
CAR year modul etc
ECU part number
BSI "" """
and for shore in few time you are a Happy guy
Cump"s
My work is my life ART TECH GARAGE
JorgePeugeot (3rd June, 2017)
Hi, thank you for your help, yes the autocom has the function of programming of keys, I have connected the autocom, and it is able to communicate ok, in fact moves the gauges of cluster , turn on lights, etcetera, I also went to the programming keys section, but obviously it asks for the pin code, the engine is 1.6 16V trim xs
thats right is a 206 1.6 16v mux, I just opened the ecu, but there are three so8 chips, one is B57554-23T-C835 texas instruments, the second one is 22BA-LM2904M, and the third one is 3043513-R836712, all three ar so8 just like the 95160 you mentioned, by the way, the 95160 is in the bsi's pcb, i have read its dump but is corrupt, the pin code is stored in the 3043513-R836712 chip?
that is great, my brothers car is a 206 2003 mux 1.6 16v ecu bosch me 7.4.4, bsi siemens with eeprom 95160, i dont have a zed pin code reader unfotunately, but i have an eeprom programmer/reader, so I just opened the ecu so i can read its eeprom and get the pin code
I just located the 95160 of the ecu! it was on the other side of the pcb!LOL
Hi thank you for you help,
yes the delphi autocom can program keys, the engine type is TUJP4 1584cc 16 v peugeot 206 Mux 2003, the ecu is bosch ME 7.4.4, i just opened the ecu and located the 95160, I am going to read it with the eeprom reader and get the dump then try to extract the pin code
your BSI dump is not totally corrupted, but there is no PIN and VIN, only mileage 162627km, you can extract pin from ECU and try to learn keys, but I think you will need to enter VIN first of all. best is to do with PP2000, it will take 30-40min to do the job, including all configurations...
CHIKO (4th June, 2017), JorgePeugeot (3rd June, 2017)
does any one know if it safe to read the ecu eeprom without desoldering? I have a S08 testing clip on hand along with the programmer/reader
You can go ahead to read in circuit if like, this ECU and SPI eeprom is safe enough to do so.
After getting dump you can decode for PIN yourself...
PIN is in address $592 - $595 and repeat in $5A2 - $5A5. Visible as plain text of ascii in HEX editor/programmer buffer and read it direct not reverse. Hope this help.
