Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 47
  1. #16
    CHIKO's Avatar
    Jun 2014
    HI
    the car is 3 YEARS parking we can not know if the chip in key still working (key drop ..............) and it hase 1 key for that i ask hime to bay new keys
  2. The Following User Says Thank You to CHIKO For This Useful Post:
    JorgePeugeot (4th June, 2017)
  3. #17
    mexanico1971's Avatar
    portugal
    Get China ZED and read pin from transporder , some models China Zed bull read pin in key , or go to a Key store
    If you are Tuga you have Autocom or other and you add the key
    Next Time give all info you can
    CAR year modul etc
    ECU part number
    BSI "" """
    and for shore in few time you are a Happy guy
    Cump"s
    My work is my life ART TECH GARAGE
  4. The Following User Says Thank You to mexanico1971 For This Useful Post:
    JorgePeugeot (3rd June, 2017)
  5. #18
    May 2017
    Quote Originally Posted by Zmann View Post
    - No need any new key if the PIN to be used is correct as the old one !
    - To proceed by totally virgin BSI the tool of Daigbox/PP2000 is, of course, needed but you have some little chance to success with this corrupted dump by your Delphi. If I remember right, it can be able to do just key (but again after car start you need the right tool then) . Now, find the correct PIN.
    - You didn't say the engine type, to dig eeprom dump from different engine ECU is performed differently.
    Hi, thank you for your help, yes the autocom has the function of programming of keys, I have connected the autocom, and it is able to communicate ok, in fact moves the gauges of cluster , turn on lights, etcetera, I also went to the programming keys section, but obviously it asks for the pin code, the engine is 1.6 16V trim xs
  6. #19
    Dec 2009
    Quote Originally Posted by mexanico1971 View Post
    CAR year modul etc
    ECU part number
    BSI "" """
    Cump"s
    Hi mate,
    No, this car is 206 MUX, what you said is for the pre-MUX car (ID 45 key)
    Quote Originally Posted by JorgePeugeot View Post
    Hi, read 95160 from ME7.4.4 ECU you will get PIN.
  7. The Following User Says Thank You to Zmann For This Useful Post:
  8. #20
    May 2017
    Hi mate,
    thats right is a 206 1.6 16v mux, I just opened the ecu, but there are three so8 chips, one is B57554-23T-C835 texas instruments, the second one is 22BA-LM2904M, and the third one is 3043513-R836712, all three ar so8 just like the 95160 you mentioned, by the way, the 95160 is in the bsi's pcb, i have read its dump but is corrupt, the pin code is stored in the 3043513-R836712 chip?
  9. #21
    May 2017
    CAR year modul etc
    ECU part number
    BSI "" """
    Cump"s
    that is great, my brothers car is a 206 2003 mux 1.6 16v ecu bosch me 7.4.4, bsi siemens with eeprom 95160, i dont have a zed pin code reader unfotunately, but i have an eeprom programmer/reader, so I just opened the ecu so i can read its eeprom and get the pin code
  10. #22
    May 2017
    I just located the 95160 of the ecu! it was on the other side of the pcb!LOL
  11. #23
    May 2017
    Hi thank you for you help,
    yes the delphi autocom can program keys, the engine type is TUJP4 1584cc 16 v peugeot 206 Mux 2003, the ecu is bosch ME 7.4.4, i just opened the ecu and located the 95160, I am going to read it with the eeprom reader and get the dump then try to extract the pin code
  12. #24
    Shmortz's Avatar
    Apr 2010
    in the middle of nowhere
    your BSI dump is not totally corrupted, but there is no PIN and VIN, only mileage 162627km, you can extract pin from ECU and try to learn keys, but I think you will need to enter VIN first of all. best is to do with PP2000, it will take 30-40min to do the job, including all configurations...
  13. The Following 2 Users Say Thank You to Shmortz For This Useful Post:
    CHIKO (4th June, 2017), JorgePeugeot (3rd June, 2017)
  14. #25
    May 2017
    Quote Originally Posted by Shmortz View Post
    great! I do not have a pp2000, I have a delphi autocom, I can try with the delphi autocom, I hope everything goes fine, thanks a lot!
  15. #26
    doctore's Avatar
    Nov 2015
    Colorado Denver
    You cannot do nothing with delphi or autocom use pp2000
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  16. The Following User Says Thank You to doctore For This Useful Post:
  17. #27
    May 2017
    does any one know if it safe to read the ecu eeprom without desoldering? I have a S08 testing clip on hand along with the programmer/reader
  18. #28
    Dec 2009
    Quote Originally Posted by doctore View Post
    Don't you think Programming key function in Autocom would help in some way ?
    I know that will not be complete but after the car started, hope his life would be easier to move further on with the car !
  19. The Following User Says Thank You to Zmann For This Useful Post:
  20. #29
    May 2017
    I am going to try the autocom anyway as I dont have a pp2000, I will order one though, i cant wait to see the motor running
  21. #30
    Dec 2009
    You can go ahead to read in circuit if like, this ECU and SPI eeprom is safe enough to do so.
    After getting dump you can decode for PIN yourself...
    PIN is in address $592 - $595 and repeat in $5A2 - $5A5. Visible as plain text of ascii in HEX editor/programmer buffer and read it direct not reverse. Hope this help.
  22. The Following User Says Thank You to Zmann For This Useful Post:
