yes!! you can find pin code in engine ecu dump , or just read eep from engine ecu and upload here dump
Hi there
I do not have the pin code of my brothers car, the car wont start its been 3 years now, sitting outside, we only have the secondary key, I mean, not the one with remote, I came to the conclusion the car wont start because of the immobilizer, so in order to find its pin code I desoldered the bsi's eeprom 95160 and gave it to electronics shop, they have read the eeprom, and gave me the .bin file, but the problem is, the program immo killer says the file is corrupt, so the code cant be read, what can i do? I need to program the keys again, is the pin code stored in the ecu's eeprom as well?
Thanks in advance!!
Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
JorgePeugeot (2nd June, 2017)
Immo killer wouldn't recognise the bsi file anyway it works with ecu eprom not BSI eprom. Post your bin file from the BSI and even if corrupted it should be possible to recover the pin code.
If it's corrupted then erase BSI eprom and reprogram the bsi with Peugeot planet.
How did you come to the conclusion that its a immobiliser problem??? have you code read the vehicle ?
this is the file, thank you very muchm951604020.zip
that is great! thanks, this is the file: m951604020.zip
that is great! thanks! here is the dump file: m951604020.zip
HI
your fill from the bsi is bad
if you wont to do this jod you need same tool and work
1/ you need pp2000/diagbox with out this tool you can do it
2/you dont have a programer so it is buter to go to the local dealer and ask hime the pin code
3/ whene you get the pin do this
1: bay 2new keys
in attachment it is a virgine fill for your bsi werait to your 95160 eprom solder to the bsi and plug your diag tool and
1/ programe the keys
2/ programe the car option ( remot / ac/ wind............)
PS: THE IMMO KILLER SOFT READ THE PIN/VIN FROM YOUR CAR 100% TESTED
IF YOU DONT HAVE PP200 DONT TATCH THE CAR GO TO THE LOKSMITH IN YOUR AIRIA
GOOD LUCK
fytfh (9th June, 2017), JorgePeugeot (2nd June, 2017), slmanfageeri (28th March, 2022)
HI
THE DELPHI TOOL CAN NOT DO THE JOB
THE PASSWORD IS IN YOUR PM (PRIVET MESSAGE)
GOOD LUCK
- No need any new key if the PIN to be used is correct as the old one !
- To proceed by totally virgin BSI the tool of Daigbox/PP2000 is, of course, needed but you have some little chance to success with this corrupted dump by your Delphi. If I remember right, it can be able to do just key (but again after car start you need the right tool then) . Now, find the correct PIN.
- You didn't say the engine type, to dig eeprom dump from different engine ECU is performed differently.
CHIKO (3rd June, 2017), JorgePeugeot (3rd June, 2017)
