You have more than 1000 pages of advice.
xito (2nd June, 2017)
You are probably looking for Digiprog or Obdstar x100pro/x300m. I doubt you are willing to pay what something like enigma cost.
rmelo84 (2nd June, 2017)
I saw many people talking about x-prog. What is good for? I know that is impossible to do all just with one tool, I have carprog for airbags, but I need something by OBD in mostly of the cars for dashboard ODO corrections and things like that. Thanks
XProg is an mcu/eeprom programmer, doesn't work via obd. I would recommend you to get one of the cheap obd tools like digiprog or obdstar, and a programmer like upa-usb or xprog (you should have both but you can start with one). So, first you try to do the km correction via obd, if that doesn't work you have the programmer as a backup. If you are in this biz (im not, just an amateur) get use to disassembling dashboards and desoldering/soldering chips, you can't do everything by obd, plus is much safer (when using cloned tools) to desolder the chip.
Why not , you can do a lot of dashboard with Carprog ,of course if it is good one.
Buy a good clone and reworked Digiprog3, and an Usb-upa, R270, or X-prog.
If You have already a CARprog than You can make many of dash with it also.
Thets the cheapiest way to make many cars.
But as everone said you should now the cars that You will be making the most...
oooh boy .............................
Reading is fundamental, asking is easy............................
