Combo Cable + IPTV Box recommendation?
Results 1 to 14 of 14
    Nov 2008
    Default Combo Cable + IPTV Box recommendation?
    Hi All,
    Am in the market for a combo IPTV + Cable box, any recommenations will be welcomed.
    Thanks in advance.
    PS : IS the Zgemma H2 worth it, is IPTV on it any good at all?
    Mar 2010
    Read about Zgemma H5 its pretty decent for the price you pay
  3. The Following User Says Thank You to clarkenuttal For This Useful Post:
    saayinla (23rd June, 2017)
    digicon's Avatar
    Jul 2009
    Even the most basic Zgemma H.2H will suffice for what you need
  5. The Following User Says Thank You to digicon For This Useful Post:
  6. #4
    happy_highlander's Avatar
    Aug 2010
    If your going to use one of the first gen zgemma like the h2 or 2s for iptv I'd advise a lightweight build such as openpli. I've found openatv 6.0 way to system intensive to stream iptv consistently. Whereas on pli 4.0 the same iptv streams are almost faultless.
    Sent from my SM-G935F using Tapatalk
  7. The Following User Says Thank You to happy_highlander For This Useful Post:
  8. #5
    Nov 2008
    wite hart lane
    I'm using, amiko mini combo, terrestrial, free to air , and iptv , picture is great .
  9. #6
    Nov 2008
    Quote Originally Posted by clarkenuttal View Post
    Thanks all for your suggestions.
    I went with the H5 but it seems a bad choice as I have ordered a second box and the turner does not seem up to scratch due to the image distortion, its completely unusable.
    Might just have to go back to one of the early gen ones.
  10. #7
    Mar 2010
    Use Zgemma H5-2TC it has single sat tuner and twin Cable Tuners. You can get one easily for ?100 and it does decent job. Flash it with Whooshbuild you would like it
  11. #8
    Nov 2008
    Thanks for the suggestions, I have bought the standard H5 boxes from 2 seperate sellers on ebay and both had serious image distortion, see attached pictures.
    You reckon the H5.2TC has a better tuner?
  12. #9
    Aug 2010
    If those images are on fta broadcast you need to be checking your cables/connections
  13. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    cunny (26th June, 2017), saayinla (27th June, 2017)
  14. #10
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by happy_highlander View Post
    Even if they were not on fta you need to check your connection (as mentioned) as that looks like bad signal.
  15. The Following 2 Users Say Thank You to cunny For This Useful Post:
    happy_highlander (26th June, 2017), saayinla (27th June, 2017)
  16. #11
    Sep 2008
    agreed if on cable how old is cabling and what splitters in use, you might need to post a picture of cables and splitters and any attenuators fitted?
  17. #12
    Nov 2008
    Quote Originally Posted by cunny View Post
    Quote Originally Posted by cactikid View Post
    Thanks for all your time to respond, What I also forgot to mention is that I have a Vu+ Cable USB tuner which I use on my existing VuSolo2 box using the same Vir Cable. Works 100% Perfectly on all channels fta or otherwise, so this distortion is only being experienced on this Zgemma H5 boxes I have tried. I have also used the same cables to setup a zgemma h2 with ybrid tuner works perfectly fine.
    Cabling was installed about 6 months ago. and here is the splitter in use which like I said works perfectly with my Cable USB tuner and on older generation zgemma cable boxes.
  18. #13
    P&D's Avatar
    May 2010
    What S/R are you getting on each box ?
    If good on the VU & crap on the Zge
    disconnect the VU see if the other then works ok
    My S/R is 22% works perfect on my Solo
  19. #14
    Sep 2008
    ahh the wrong splitter again as vm use a 5-1000mhz one and your one will let in interference,and what type quality of cables in use might also be bad,interesting as a better quality built box has no issues.
  20. The Following 2 Users Say Thank You to cactikid For This Useful Post:
    notel98 (12th November, 2017), P&D (28th June, 2017)
