Results 1 to 7 of 7
    unu's Avatar
    Oct 2010
    EUROPE
    Default JCB COMPACT PROD ECU MIDI pinout !
    Hello members !
    Someone can help me with pinout for this ECU ?
    JCB 728 / 80002
    COMPACT PROD: ECU MIDI
    I see there 3 plugs but pins is unmarked in any way.
    Thank you for your kindness !
    U
    unu's Avatar
    Oct 2010
    EUROPE
    Ok , I solved with this.
    But mcu ( SAK-C167 ) doesn't work , it's in a reset loop , and , of course , do not communicate via CAN.
    And I didn't find any damaged circuit.
    Inside , I found one eeprom 93C86 and one flash 29F400.
    Someone did read one of these ?
    Regards , U
    HI I need to pinout for this ecu can you share with me?
    Jan 2022
    Is this the correct ECU you require?
    KARLOVE POŚLADY
    Hi all! I can repair them, or i i can sell the same ecu for 8080 model machine, with quick hitch setup, i can reprogram for other config as well. Pinout is available in service manual pdf, dedicated for each machine.
    Regards:
    Bob
    Mar 2019
    Quote Originally Posted by kredka74 View Post
    Regards:
    Bob
    Hello i need to buy another unit or fix my. Can you reach my on m email xxxxxxxxxx Thanks
    KARLOVE POŚLADY
    Hi i need ur email, i can repair and supply module plug/play for ur machine 8080 jcb, just need a details about ur machine. I need old unit as well for recycling, thats UE rules.
    Regards:
    Bob
